joffa1 Member 143 Member For: 6y 9m 13d Posted 21/02/22 03:25 AM Author Share Posted 21/02/22 03:25 AM So big thread dig but surprise surprise my car sounds like a tractor again just like you guys said it would. So I’m thinking this time as it’s most likely the same problem I will have a go at doing it myself. Is this the problem part that cracks and these the problem bolts? Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,128 Member For: 9y 2m 26d Gender: Male Location: South Australia Posted 21/02/22 03:29 AM Share Posted 21/02/22 03:29 AM If it sounds like a tractor then it might be the turbo to manifold fasteners. Get in there and see what's loose. Link to comment Share on other sites More sharing options...
joffa1 Member 143 Member For: 6y 9m 13d Posted 21/02/22 04:02 AM Author Share Posted 21/02/22 04:02 AM Yeah we went through all this last time it happened. If you read back it’s apparently related to cracked turbine housing so just trying to narrow down again where I’m looking exactly and what does and doesn’t have to be removed. Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,128 Member For: 9y 2m 26d Gender: Male Location: South Australia Posted 21/02/22 04:21 AM Share Posted 21/02/22 04:21 AM Take the heat shields off and try to pinpoint the noise. 1 Link to comment Share on other sites More sharing options...
joffa1 Member 143 Member For: 6y 9m 13d Posted 21/02/22 05:26 AM Author Share Posted 21/02/22 05:26 AM Will do but I’m almost positive it’s exact same problem as last time. Thing is I had Casey Automotive make the repair last time so hoping to have a go at it myself this time and try and make sure it won’t happen again. Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,128 Member For: 9y 2m 26d Gender: Male Location: South Australia Posted 21/02/22 05:48 AM Share Posted 21/02/22 05:48 AM 1 hour ago, joffa1 said: If you read back I just did, fark I'm a helpful bastard! Stick a bit of vac line in your ear hole and find the noise like that. Better yet use a pair of chassis ears. 1 Link to comment Share on other sites More sharing options...
joffa1 Member 143 Member For: 6y 9m 13d Posted 21/02/22 06:48 AM Author Share Posted 21/02/22 06:48 AM 😂 you certainly helped out a lot last time it happened. I still had to get someone else to do it though! Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,128 Member For: 9y 2m 26d Gender: Male Location: South Australia Posted 21/02/22 06:54 AM Share Posted 21/02/22 06:54 AM Haha apparently I was less cranky a few years ago 1 1 Link to comment Share on other sites More sharing options...
joffa1 Member 143 Member For: 6y 9m 13d Posted 27/04/22 03:11 AM Author Share Posted 27/04/22 03:11 AM So I’ve got it booked in at Casey Automotive again as doubtful I’ll have time to investigate myself. if indeed it is a cracked turbine housing as people have pointed to where do I source a replacement. Is there a better aftermarket option that hopefully won’t crack again? appreciate the help. Link to comment Share on other sites More sharing options...
