SHMIKO_S14A New Member 22 Member For: 6y 8m 23d Posted 14/01/18 03:39 AM Share Posted 14/01/18 03:39 AM Hey guys, started my car up yesterday after giving it a wash and it’s making a whining noise in all 4 gears under any sort of load. Also makes the noise in reverse. Does not make the whining noise when it’s in either park or neutral free revving so I’m assuming it’s trans related. It will even do it when I put my foot on the brake and stall it up a bit. The whining sound coincides with the RPM of the engine as in it gets higher pitched with higher RPM. The transmission has had an oil flush about 6 months ago along with a billet servo and new shift solenoid done at MV auto’s and has been generally running fine since then although it does slip when hitting 3rd/4th gear under full throttle at higher RPM’s sometimes. Any ideas as to what this could be? I know I’m probably looking down the road of a trans rebuild but hoping someone else has had this whining noise before and knows what the cause was. Cheers in advance. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,239 Member For: 15y 11m 19d Gender: Male Location: Melbourne Posted 14/01/18 03:49 AM Share Posted 14/01/18 03:49 AM A transmission issue after a wash? Are you sure it only started when you washed it? What's the model and modifications? Link to comment Share on other sites More sharing options...
Rab WOT? Moderating Team 10,980 Member For: 11y 1m 3d Gender: Male Location: Frankston, 3199 Posted 14/01/18 04:38 AM Share Posted 14/01/18 04:38 AM Probably a stupid question, but the noise isn't coming through the sound system is it? Link to comment Share on other sites More sharing options...
SHMIKO_S14A New Member 22 Member For: 6y 8m 23d Posted 14/01/18 04:55 AM Author Share Posted 14/01/18 04:55 AM BA Barra 240T BTR auto. Yep it only started after I washed it which I found strange but I’m sure it was coincidental lol. Nope definitely not coming through the sound system lol. It’s mechanical. 1 Link to comment Share on other sites More sharing options...
SHMIKO_S14A New Member 22 Member For: 6y 8m 23d Posted 14/01/18 09:08 AM Author Share Posted 14/01/18 09:08 AM (edited) Sorry forgot to list mods, PWR front mount, 650cc Siemens injectors, 4 inch dump into 3.5 inch with high flow cat, Walbro 255. And obviously the transmission work mentioned in my first post. Edited 14/01/18 09:10 AM by SHMIKO_S14A Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,239 Member For: 15y 11m 19d Gender: Male Location: Melbourne Posted 14/01/18 10:08 AM Share Posted 14/01/18 10:08 AM Have you had your head underneath it to be sure its coming from the transmission? Link to comment Share on other sites More sharing options...
SHMIKO_S14A New Member 22 Member For: 6y 8m 23d Posted 15/01/18 07:59 AM Author Share Posted 15/01/18 07:59 AM Yep already done that, coming from the transmission as far as I can tell. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,239 Member For: 15y 11m 19d Gender: Male Location: Melbourne Posted 15/01/18 08:34 AM Share Posted 15/01/18 08:34 AM from the bellhousing or the transmission box itself? Link to comment Share on other sites More sharing options...
SHMIKO_S14A New Member 22 Member For: 6y 8m 23d Posted 31/01/18 08:25 AM Author Share Posted 31/01/18 08:25 AM Ended up having the transmission fully rebuilt and noise is now gone, took it in to a good transmission place and they said it was the converter bearings squealing so decided to bite the bullet and get it built and strengthened. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,239 Member For: 15y 11m 19d Gender: Male Location: Melbourne Posted 31/01/18 11:15 AM Share Posted 31/01/18 11:15 AM why didn't they just fix the converter? no point getting the gearbox re-built unless you're also going to strengthen the motor a bit, being a skinny-rod BA, imho. But as long as you're happy, it's all good Link to comment Share on other sites More sharing options...
