Moods New Member 4 Member For: 6y 5m 21d Posted 03/11/17 01:10 PM Share Posted 03/11/17 01:10 PM Have my fg f6 at a reputable workshop. Getting tuned with hp tuners the car idles perfectly but when they go to run it on the dyno at 2500rpm the ecu sh*t itself. The 5th cylindre is dead the ecu doesnt seem to be pulsing the injector when the injector is earthed the injector pulses, the coils are all fine. Swaped another ecu got it reflashed by ford to suit the car and now the same issue occured while the car was getting tuned. What could be causing this issue Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 10m 25d Gender: Male Location: Adelaide Posted 03/11/17 09:35 PM Share Posted 03/11/17 09:35 PM What’s the reputable workshop ? Link to comment Share on other sites More sharing options...
Moods New Member 4 Member For: 6y 5m 21d Posted 03/11/17 11:25 PM Author Share Posted 03/11/17 11:25 PM Wont name the workshop, just incase sh*t dont turn out. But they have done plenty of fords and a couple of 1000hp barras Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,128 Member For: 9y 2m 26d Gender: Male Location: South Australia Posted 03/11/17 11:39 PM Share Posted 03/11/17 11:39 PM 10 hours ago, Moods said: The 5th cylindre is dead the ecu doesnt seem to be pulsing the injector when the injector is earthed the injector pulses Check it at the ecu pinout. This will rule out a faulty wire. Link to comment Share on other sites More sharing options...
Moods New Member 4 Member For: 6y 5m 21d Posted 03/11/17 11:46 PM Author Share Posted 03/11/17 11:46 PM Checked it at the wire for that cylinder at the wire that comes out the ecu checked it about 5 cm from ecu conector. Striped the wire and when you touch a wire to thed striped wire and the chassis the injectort will pulse Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,128 Member For: 9y 2m 26d Gender: Male Location: South Australia Posted 03/11/17 11:49 PM Share Posted 03/11/17 11:49 PM Loose or open pin at the connection? Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,303 Member For: 16y 15d Gender: Male Location: Melbourne Posted 03/11/17 11:52 PM Share Posted 03/11/17 11:52 PM if it's not the injector, the coil driver is known to fail occasionally in these ECU's, which earth's out the coil and causes it to immediately corrode the connector and joint, which makes the coil driver issue worse - negative feedback loop essentially... If the parts that die aren't replaced when the ECU is replaced (the loom and associated coil and plug) then it can kill a new ECU in the same way with the earthed out coil. That's my best guess Link to comment Share on other sites More sharing options...
Moods New Member 4 Member For: 6y 5m 21d Posted 04/11/17 12:02 AM Author Share Posted 04/11/17 12:02 AM The only thing is that when the car idles and its on 5 cylinders when the injector wire is earthed at tbe ecu end the injector will pulse and the car will sound like its Running on 6 cylinders for a split second. Very weird Link to comment Share on other sites More sharing options...
JVK Silver Donating Members 751 Member For: 18y 4m 7d Gender: Male Location: North West Hot Hell,VIC Posted 11/11/17 07:44 AM Share Posted 11/11/17 07:44 AM Check your intake manifold gasket for leaks. Read a few more threads in this section regarding missing or no injector pulse. Fg ecu will drop injector pulse on some cyls if it picks up specific coil misfire events. Link to comment Share on other sites More sharing options...
