Boosted el New Member 5 Member For: 6y 5m 20d Posted 01/11/17 11:19 PM Share Posted 01/11/17 11:19 PM Hi I’m finally getting around to wiring my 96 el xr6 witch I’ve done a bf Barra conversation with a malwood built t56 with transducer fitted and a Vipec v88 ecu I’m wondering if anyone would have any wiring diagrams or any sort of information on how to go about my input output list that may help get this beast up and running again any help will be much appreciated thanks Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,292 Member For: 16y 10d Gender: Male Location: Melbourne Posted 01/11/17 11:31 PM Share Posted 01/11/17 11:31 PM sounds epic... but nobody on this forum has done that conversion before... so I think you'll be doing some pioneering 1 Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 10m 20d Gender: Male Location: Adelaide Posted 02/11/17 12:03 AM Share Posted 02/11/17 12:03 AM You should be able to grab the E series wiring diagram which will give you your Body control inputs to the vipec, the BF engine and accessories are easy enough to work out just by looking at it and making a new loom or even using the B series loom to the outputs on the vipec what do you want to know as this will be fairy straight forward if you can understand the e series wiring diagram cable TB and away you go unless the 88 has FBW control Link to comment Share on other sites More sharing options...
Boosted el New Member 5 Member For: 6y 5m 20d Posted 02/11/17 12:14 AM Author Share Posted 02/11/17 12:14 AM Yeah I’m just working out the inputs atm would the cam phasers solenoids be outputs from the vi pec as the cam position sensor would be the input for that system is that correct and also I have the afx ntk wideband kit witch is it the 4” dump would I still require a down stream sensor or will the afx be enough and I already have the cable throttle body thanks for the reply Just can’t seem to put pictures up? Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,292 Member For: 16y 10d Gender: Male Location: Melbourne Posted 02/11/17 12:32 AM Share Posted 02/11/17 12:32 AM instructions to post pics are here -> http://www.fordxr6turbo.com/forum/topic/92470-how-to-put-images-in-your-post/ Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,117 Member For: 9y 2m 22d Gender: Male Location: South Australia Posted 02/11/17 01:57 AM Share Posted 02/11/17 01:57 AM 1 hour ago, Boosted el said: cam phasers solenoids be outputs from the vi pec Correct. 1 hour ago, Boosted el said: cam position sensor would be the input Correct. 1 hour ago, Boosted el said: would I still require a down stream sensor Nope. Inputs are the things that the ecu reads such as temp sensors and position sensors and outputs are the things that the ecu controls like thermo fan set points and idle control valves etc. Seems obvious when it's put like that but sometimes it helps to go back to basics 1 Link to comment Share on other sites More sharing options...
Bara58 Donating Members 116 Member For: 11y 9m 2d Gender: Male Location: Bowen, Qld Posted 02/11/17 08:23 PM Share Posted 02/11/17 08:23 PM http://www.vi-pec.com/techdata/documentation You should be able to get your wiring info from the above link, I used to run a vipec v88 in my XH with turbo Barra unfortunately don't have any of the details anymore (gave it away to the bloke that bought the ecu) but you should be able to work out using the ViPec site pretty easy the 88 will run the ethrottle as well. Don't know if this helps but this is the I/O schedule I used sadly I have deleted the tune but will keep searching as I might have a USB with a tune that will get you started. 1 Link to comment Share on other sites More sharing options...
Boosted el New Member 5 Member For: 6y 5m 20d Posted 02/11/17 10:46 PM Author Share Posted 02/11/17 10:46 PM Thanks heaps for that mate you are a dead set legend ? that’s exactly what I was chasing and that would be awesome thanks I’ll keep u guys posted on how I go with it all so keen to get this back up and running ? 21 hours ago, Puffwagon said: Inputs are the things that the ecu reads such as temp sensors and position sensors and outputs are the things that the ecu controls like thermo fan set points and idle control valves etc. Seems obvious when it's put like that but sometimes it helps to go back to basics Thanks heaps for clearing that up for me mate wasn’t to sure on a down stream sensor Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,117 Member For: 9y 2m 22d Gender: Male Location: South Australia Posted 02/11/17 11:00 PM Share Posted 02/11/17 11:00 PM 10 minutes ago, Boosted el said: down stream sensor Just to explain why; the stock ecu has it to compare pre and post cat sensor voltage to determine if the cat is working properly. It's not needed in aftermarket applications. Link to comment Share on other sites More sharing options...
Bara58 Donating Members 116 Member For: 11y 9m 2d Gender: Male Location: Bowen, Qld Posted 03/11/17 02:52 AM Share Posted 03/11/17 02:52 AM OK have found the last run file I had on a usb drive, I'll put it here but may not work, if not pm your email address and I'll attach to an email. See below or the attachment? XH GTX3582R 1000 cc injectors and new cam settings (2).pcl Link to comment Share on other sites More sharing options...
