Jakexr6 New Member 8 Member For: 7y 17d Posted 17/08/17 05:46 AM Share Posted 17/08/17 05:46 AM Hey all just wondering about a set of pf07 enkei rims and if they will fit my car I'm not sure about the specs on offsets, center bore etc it's a 2006 bf xr6 Na if you could provide the max recomended specs for the car is really appreciate it also the new rims are Wheel Size: 17x7.5 Offset: +45 Hub Bore: 75 Bolt Pattern: 5x114.3. Thanks in advance Link to comment Share on other sites More sharing options...
camo86T Silver Donating Members 1,810 Member For: 10y 2m 11d Gender: Male Location: SW Sydney Posted 17/08/17 07:17 AM Share Posted 17/08/17 07:17 AM (edited) If you put rims that narrow on a falcon it will fall over. Good for skids in an NA though... Centre bore is larger as usual on jap wheels, just need centering rings to suit. Falcon is 70.1 from memory. 45 offset may normally be a bit close to control arms on a decent width but 7.5 is puny so won't be a problem. Your car and your coin, but it will look sh*t; on a falcon 17's can look alright if you have decent width and offset but those rims don't have either. Look thru this thread for ideas and sizes that work: http://www.fordxr6turbo.com/forum/index.php?app=forums&module=forums&controller=topic&id=48416 Edited 17/08/17 07:22 AM by camo86T changed CB size 1 Link to comment Share on other sites More sharing options...
