PyRo New Member 22 Member For: 9y 8m 29d Posted 23/07/17 10:40 PM Share Posted 23/07/17 10:40 PM Hi guys, Last week, the poor little turbo went and had a heart attack, sounded like it was over boosting and then a metal scraping noise :( When taking it out, it appeared that the rubber hose to the actuator was split, I couldn't find anything else wrong with it. Any other ideas what may have have caused it? I was going to purchase a manufactured turbo, however, I can get them through Ford for the same cost thanks to work discount. She was setup/tuned at Pitlane and driven approximately 130,000km's since the the modifications (170k total). Other than regularly servicing, the only part I have purchased is a brake light switch because of the ABS issue. The car is running at 320rwkw @15psi with: 60lb injectors Stage 2 intercooler 4" to 3.5" stainless steel exhaust Ported GT3576 I am thinking of ordering: GT3576 New Gaskets Two rubber hoses going into the turbo Actuator (Would it have been modified or the stock one is normally used?) Braided Oil Lines (If suggested, or do you think generally there is no need?) Any advise would be great. Thank you Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 10m 20d Gender: Male Location: Adelaide Posted 23/07/17 10:58 PM Share Posted 23/07/17 10:58 PM Get your tuner to fit and re tune to suit your engines current capabilities as 130,000kms is a long time for a tune to still be "perfect" might be work a call to see if they can supply and fit as you might end up with more options for the same money Link to comment Share on other sites More sharing options...
PyRo New Member 22 Member For: 9y 8m 29d Posted 24/07/17 12:35 AM Author Share Posted 24/07/17 12:35 AM Hi, We will be fitting it, we change all of our engine / turbos for our race cars already, it's already on the hoist with the turbo removed. Unfortunately, the misses will not approve another tune, I don't need it to run at maximum, if it runs fine, I have no problem. It was running fine before hand. If I was going to re-tune, I would buy a bigger turbo, she won't approve that either lol. As for the parts, I will be ordering direct due to our discount, I am getting the full turbo and housing brand new for the price of just a manufactured without housing change. Just need to figure these last few things out, then we will hopefully get it fitted up this week Thank you 1 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,292 Member For: 16y 10d Gender: Male Location: Melbourne Posted 24/07/17 12:40 AM Share Posted 24/07/17 12:40 AM sounds like you need a new missus who does approve who has confirmed if there's not something else that caused the turbo to fail that might cause a replacement to fail in the same way? Link to comment Share on other sites More sharing options...
PyRo New Member 22 Member For: 9y 8m 29d Posted 24/07/17 01:02 AM Author Share Posted 24/07/17 01:02 AM Hi, Unfortunately the ye old ball and chain :( That is the only fault we can see, that's why I want to replace all of the other components if needed as well. Will the stock actuator handle the 15psi? Thank you Link to comment Share on other sites More sharing options...
PyRo New Member 22 Member For: 9y 8m 29d Posted 24/07/17 01:18 AM Author Share Posted 24/07/17 01:18 AM Hi, Disregard, I have checked and that will do fine. Thank you Link to comment Share on other sites More sharing options...
IRONMANTIS New Member 23 Member For: 6y 9m 29d Gender: Male Location: SEQ Posted 31/07/17 12:18 PM Share Posted 31/07/17 12:18 PM I would replace the standard turbo oil line with an earls braided item and inline filter ($150ish), if the standard filter is blocked it'll blow your new turbo aswell, a tune wouldn't hurt either and should only cost a few hundred if the car is already tuned. Prevention is better than a cure! Would the misso rather part out a few hunj or a thousand plus every time a turbo blows Link to comment Share on other sites More sharing options...
Panda Eyes flame magnet Gold Donating Members 5,673 Member For: 15y 11m 4d Gender: Male Location: adelaide hills- 'race air' central Posted 02/08/17 09:27 AM Share Posted 02/08/17 09:27 AM I would keep the original line, but remove the filter altogether. the turbo can easily cope with whatever will be pumped up the line from the sump, but not with lack of oil... even an earls filter can clog. Link to comment Share on other sites More sharing options...
