peps New Member 18 Member For: 9y 4m Posted 02/06/17 12:15 PM Author Share Posted 02/06/17 12:15 PM 295/35 18 Link to comment Share on other sites More sharing options...
Red13 New Member 14 Member For: 3y 7m 13d Posted 05/09/20 10:00 AM Share Posted 05/09/20 10:00 AM (edited) On 30/05/2017 at 7:33 PM, OZYWALKER said: Fronts will clear fine, may need to roll the guards depending on how low the car is. Rears are a different story, need measurements of the tray and chassis from a wheel with a known offset. So do you know for sure that the 18x9 +25 will fit the front(inside and out). I think the front is about 10 to 15 mm down on my fg xr6t ute (mca red series coilovers) about to order rims just so much info and some say stuff will fit and some say it won't. Also thinking 18x9 +35 or +25 for the rear aswell Edited 05/09/20 10:02 AM by Red13 Link to comment Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,751 Member For: 12y 8m 28d Posted 05/09/20 10:45 AM Share Posted 05/09/20 10:45 AM Fronts at +25 will fit but will need a narrow tyre, and maybe a touch more camber to keep the guards happy. Rears will fit pretty easy at +25 They fit 10's with ease at +40. Link to comment Share on other sites More sharing options...
Red13 New Member 14 Member For: 3y 7m 13d Posted 06/09/20 03:24 AM Share Posted 06/09/20 03:24 AM (edited) So I'm guessing a 9.5 for the rear at a +35 would sit quite nice then it the 10 at 40 are good. Would +35 be better or would that be getting close to the suspension. How narrow a tyre I wouldn't like anything under a 245 with 255 preferably. Edited 06/09/20 03:26 AM by Red13 Link to comment Share on other sites More sharing options...
Wyatt Donating Members 70 Member For: 4y 8m 27d Gender: Male Location: Cairns Posted 07/09/20 09:59 AM Share Posted 07/09/20 09:59 AM I've Koya SF09 20x8.5S 25ET with 245x30 up front (to protect rim I guess) on an FG ute along side MCA purples, looks to be a gap of around 40mm from suspension bits inside of tyre, guard lip is rolled slightly and they have never scraped. Rears are SF09 20x11D 30ET with 295x30 and similar gap to springs. there's currently a gap of 20mm tyre to guard and as kings springs slowly sag it makes them look better. There's somethin about any car with full guards. Has 355mm xyz brakes which have a big gap of around 40mm to rim in case anyone was wondering, previous owner could have put on 380mm rotors. lol Hope that helps Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,291 Member For: 16y 8d Gender: Male Location: Melbourne Posted 07/09/20 10:05 AM Share Posted 07/09/20 10:05 AM @Wyatt - pics are a must Link to comment Share on other sites More sharing options...
Red13 New Member 14 Member For: 3y 7m 13d Posted 07/09/20 10:11 AM Share Posted 07/09/20 10:11 AM 5 minutes ago, Wyatt said: I've Koya SF09 20x8.5S 25ET with 245x30 up front (to protect rim I guess) on an FG ute along side MCA purples, looks to be a gap of around 40mm from suspension bits inside of tyre, guard lip is rolled slightly and they have never scraped. Rears are SF09 20x11D 30ET with 295x30 and similar gap to springs. there's currently a gap of 20mm tyre to guard and as kings springs slowly sag it makes them look better. There's somethin about any car with full guards. Has 355mm xyz brakes which have a big gap of around 40mm to rim in case anyone was wondering, previous owner could have put on 380mm rotors. lol Hope that helps Hey thanks mate I've decided to go with the sf04 in an 8.5+25 front and a 9.5+25 rear and see how a 255/35/19 and 275/35/19 go. I think I need to bring the back down to match the front so its flat also as they are still stock springs in the back so it sits quite high. Was thinking of getting herrod spring though haven't made up my mind between them and kings yet. Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 22d Gender: Male Location: Perth Posted 07/09/20 10:11 AM Share Posted 07/09/20 10:11 AM Ute rear is different to sedan Either go 255/40 on the front or 285/30 on the rear. Will match OD Link to comment Share on other sites More sharing options...
Red13 New Member 14 Member For: 3y 7m 13d Posted 07/09/20 10:14 AM Share Posted 07/09/20 10:14 AM Makes sense. Might see if a 255/40 will fit Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 22d Gender: Male Location: Perth Posted 07/09/20 10:19 AM Share Posted 07/09/20 10:19 AM You got ute? If so go 10.5 on the rear. Link to comment Share on other sites More sharing options...
