FGX G6E TURBO BUILD
Upinder
  • Member For: 11y 7m 22d
haha I don't really care what others run my goal was to build a car that is well presented I wont be doing a cage or chute so I really only have a few chances to run a good time at calder, car only has 15 xxx on it 😞
Nahh at the time I did the fuel system all the mechanical fuel pump kit removed AC and I still wanted AC there a few kits now that you can keep AC so we will see how the 3 walbro pumps go if we run out of fuel then its and excuse to move to mechanical pump haha
yeah goal is to have one pump on all the time then the other 2 are staged to come on.
Limited by 4 bar map sensor so that is max boost for now haha
I think Anel F6 had the same set up and he maxed it out just over 1000rwkw
there is enough injector there that is for sure
1650cc Primary
2200cc Secondary
  • Dropping a turd
  • Member For: 16y 5m 20d
Probably need  40 - 50 psi and 7000+ rpm for over 1000rwkw. My tuner made 1055 at 38psi at 7k a few years ago. Since then has gone way over 1100
Good luck with it. Will need tonnes of fuel..
