barraturtle New Member 4 Member For: 7y 1m 13d Gender: Male Location: Gold Coast QLD Posted 03/05/17 12:11 AM Share Posted 03/05/17 12:11 AM Hey all, Having a boost issue with my BA (Cooler, 4 inch dump & exhaust, injectors, X4 with custom tune 297kw@14psi, currently running custom 10psi safe tune), 1st will boost to about 5psi the 0psi, 2nd will spool up then 0psi, currently nursing. No fault codes appearing, so far have checked/replaced, -piping, joiners & BOV vacuum lines (replaced the sh*t turbo intake & throttle body joiners & vac lines with silicones and T-bolts) -intake/exhaust & turbo manifold bolts (exhaust manifold bolts were loosish to my suprise) -wastegate solenoid to actuator & turbo lines. (solenoid maintenance at the same time) -wastegate for movement (not sticking) I am leaning towards a failing actuator diaphragm or spring because when I checked that the wastegate was moving it seemed that the spring tension was quite soft (checked the tension on a spare diesel turbo) in comparison. any input is greatly appreciated. Link to comment Share on other sites More sharing options...
Typhoon Member 564 Member For: 19y 7m 1d Gender: Male Posted 03/05/17 04:38 AM Share Posted 03/05/17 04:38 AM Sounds like you have checked the basics up to now. Have you considered removing the boost pressure sensor and cleaning it or at least having a look at it? The part looks like this http://www.ebay.com.au/itm/GENUINE-FORD-BA-BF-FG-MK2-FALCON-SX-SY-TERRITORY-TURBO-BOOST-PRESSURE-SENSOR/291215473643 On a standard BA xr6 turbo it will be located on the intake pipe near the battery. If this is faulty it could cause the problems your describing. Should have a trouble code associated with this type of sensor failure, however with a tuned car who knows. Sounds like a waste gate problem Good luck mate Link to comment Share on other sites More sharing options...
barraturtle New Member 4 Member For: 7y 1m 13d Gender: Male Location: Gold Coast QLD Posted 05/05/17 09:13 PM Author Share Posted 05/05/17 09:13 PM ok for some weird reason my car has fixed itself (not complaining), I will still pull of the BPS for inspection and a clean this weekend, Has this ever happened to anyone before? Link to comment Share on other sites More sharing options...
skidxr6t skids Donating Members 2,754 Member For: 11y 3m 27d Gender: Not Telling Posted 05/05/17 11:09 PM Share Posted 05/05/17 11:09 PM yes they love to run inconsistent. things like bad electrical connections (earthing etc), fuel etc make a big difference. Link to comment Share on other sites More sharing options...
Chrisooo97 New Member 11 Member For: 6y 3m 11d Posted 13/01/18 12:18 PM Share Posted 13/01/18 12:18 PM Any of you guys know where the bps is located on a fg turbo ? Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,127 Member For: 9y 2m 26d Gender: Male Location: South Australia Posted 13/01/18 12:29 PM Share Posted 13/01/18 12:29 PM Link to comment Share on other sites More sharing options...
