masda74 To Loud Gold Donating Members 4,112 Member For: 12y 3m 26d Gender: Male Location: WA, Perth Posted 10/05/17 10:41 AM Share Posted 10/05/17 10:41 AM So what you are saying is that a Custom bent spanner is needed for an F6. There is your C word for you. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,238 Member For: 15y 11m 18d Gender: Male Location: Melbourne Posted 10/05/17 12:58 PM Share Posted 10/05/17 12:58 PM yep Link to comment Share on other sites More sharing options...
HOTXR6T Donating Members 58 Member For: 5y 8m 9d Gender: Male Location: SA Posted 29/09/18 01:31 PM Share Posted 29/09/18 01:31 PM Is the fg XR6 TURBO the same as the earlier models? Link to comment Share on other sites More sharing options...
camo86T Silver Donating Members 1,810 Member For: 10y 1m 16d Gender: Male Location: SW Sydney Posted 29/09/18 10:14 PM Share Posted 29/09/18 10:14 PM FG F6 turbo is the same as B series, FG XR6T turbo is slightly different, read this thread Given the thread you're posting in, if you're asking whether the same Earl's filter kit will work on either, answer is yes. 1 Link to comment Share on other sites More sharing options...
HOTXR6T Donating Members 58 Member For: 5y 8m 9d Gender: Male Location: SA Posted 30/09/18 01:52 AM Share Posted 30/09/18 01:52 AM Thanks, Link to comment Share on other sites More sharing options...
Mixalis Member 38 Member For: 10y 10m 9d Posted 09/03/19 10:15 AM Share Posted 09/03/19 10:15 AM Hi guys, I just removed the factory hardline out of my F6 Typhoon and replaced it with a braided kit from GCG turbos. I noticed that the AN adaptor that screws into the turbo does not actually feed all the way flush against the turbo, seems that the flared end of the adaptor must seal against the restrictor way before it uses all the thread on the adaptor. Does the Earls kit do the same thing? Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,238 Member For: 15y 11m 18d Gender: Male Location: Melbourne Posted 09/03/19 10:18 AM Share Posted 09/03/19 10:18 AM yep, that's correct. 1 Link to comment Share on other sites More sharing options...
Mixalis Member 38 Member For: 10y 10m 9d Posted 09/03/19 10:22 AM Share Posted 09/03/19 10:22 AM Cheers Keith, just wanted to double check that one. Does the hole in the factory bolt that holds the banjo seat over the restrictor in the turbo? Link to comment Share on other sites More sharing options...
FordFan2016 New Member 2 Member For: 4y 7m 22d Posted 10/12/19 07:07 AM Share Posted 10/12/19 07:07 AM I just did the change, and pulled out the oil filter to gain better access. It all went quite well (apart from having to cut the old line to get it out, but that doesn't matter, does it?). I had to buy a different banjo to mount on the turbo (my Ford FGX is an ex-police unit, so they probably modified it in some way), but it all went together in the end. When I removed the fitting in the block there was no filter in it anyway, so I don't know if the police removed it or Ford when I had it serviced. The Ford agent told me it had a replacement turbo fitted about 30,000km ago, so something went wrong, and maybe they removed the filter then. So thank you very much for this post, it was very clear, and I appreciate the trouble to which you went in order to post it. Many thanks. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,238 Member For: 15y 11m 18d Gender: Male Location: Melbourne Posted 10/12/19 08:11 AM Share Posted 10/12/19 08:11 AM yeah, the mechanic probably removed your filter when the turbo failed as that's a common failure point for the turbo's. Link to comment Share on other sites More sharing options...
