discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 16y 4m 25d Gender: Male Location: Probably above atmospheric pressure Posted 12/03/17 03:34 AM Share Posted 12/03/17 03:34 AM (edited) I got 202 missing the chair stopper from the 209 run prior so I beat you nyah nyah Your record is no boost AND no fuel, I had fuel coz racecar Edited 12/03/17 03:35 AM by discostig Link to comment Share on other sites More sharing options...
Rab WOT? Moderating Team 10,980 Member For: 11y 1m 24d Gender: Male Location: Frankston, 3199 Posted 12/03/17 03:49 AM Share Posted 12/03/17 03:49 AM I'm sure Ralph was trying to make up classes a while back for some event too. Link to comment Share on other sites More sharing options...
cruiser Donating Members 19 Member For: 7y 1m 8d Posted 13/03/17 12:18 AM Author Share Posted 13/03/17 12:18 AM (edited) Hi guys Latest to my small problem It seems that the sound is coming from the IR Blow off valve Both fast and normal and take off from lights normal speed it just not stop Tried adjusting control on the side of blow off valve ( Does nothing ) So I would think the blow off valve is broken The name on it is IR Blow off valve It looks like an easy replacment Question is this a good Blow off valve or should I replace with another ?? Question Where do I purchase Question Can I install myself Thanks again guys really appreciate your comments Cheers Steve Edited 13/03/17 12:45 AM by Rab Double posts and formatting Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,291 Member For: 16y 9d Gender: Male Location: Melbourne Posted 13/03/17 12:51 AM Share Posted 13/03/17 12:51 AM Looks like a cheapie, but I don't know it, personally... you can tell if it's leaking if you just idle the car and there's air blowing out of that "trumpet" section, as it shouldn't be blowing any air out under vacuum/idle conditions. Get a stock one and put it in there, if necessary. Yes, you can install yourself if you have the right tools to get the clamps on the hoses undone/done-up. Link to comment Share on other sites More sharing options...
cruiser Donating Members 19 Member For: 7y 1m 8d Posted 13/03/17 01:17 AM Author Share Posted 13/03/17 01:17 AM Thanks did blow off values come out in the Fgs stock If so I should contact ford then for a stock one ?? Your comments Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,291 Member For: 16y 9d Gender: Male Location: Melbourne Posted 13/03/17 01:22 AM Share Posted 13/03/17 01:22 AM Yes, stock XR6T's have a "re-circulation" valve, which is a form of blow-off valve that recirculates the waste air back into the air intake instead of releasing it to atmosphere like the aftermarket one you have. You can get one from a wrecker (cheaper) or Ford (more expensive). It's the same BOV for BA/FG. Or you can buy another aftermarket one (more expensive than Ford) Link to comment Share on other sites More sharing options...
masda74 To Loud Gold Donating Members 4,112 Member For: 12y 4m 19d Gender: Male Location: WA, Perth Posted 13/03/17 02:42 AM Share Posted 13/03/17 02:42 AM I might be wrong here, so please correct me if I am wrong. In that picture it looks like the adjustment screen can be tightened up to recirculate the air back into the system instead of ventilating to the environment. Do all Blow off valves do this? If if you tighten the screen does the sound of a boost leak actually reduce? Link to comment Share on other sites More sharing options...
OZYWALKER XR50T Gold Donating Members 2,795 Member For: 10y 11m 17d Gender: Male Location: Western Sydney Posted 13/03/17 02:43 AM Share Posted 13/03/17 02:43 AM On dual port valves that's correct.All aftermarket valves are a lot louder compared to the stocked though. Link to comment Share on other sites More sharing options...
masda74 To Loud Gold Donating Members 4,112 Member For: 12y 4m 19d Gender: Male Location: WA, Perth Posted 13/03/17 02:56 AM Share Posted 13/03/17 02:56 AM After doing a bit of a search, I found this https://www.neon-technologies.com.au/products/dual-port-blow-off-valve-bolt-on-for-audi-s3-a4-a6-s3-and-tt Seems like it is a dual port blow off valve. So if it does recirculate and the OP does turn the screen to harder, will he still hear hear it as much if it is recirculating? Link to comment Share on other sites More sharing options...
OZYWALKER XR50T Gold Donating Members 2,795 Member For: 10y 11m 17d Gender: Male Location: Western Sydney Posted 13/03/17 05:08 AM Share Posted 13/03/17 05:08 AM With dual port bovs the two outlets are staggered so the recirculating side opens before the externally vented. So if its working as it should when cruising it will be quiet and when you be smashn the boost she'll be loud AF. 1 Link to comment Share on other sites More sharing options...
