Slowxr6t Member 516 Member For: 5y 4m 21d Location: New zealand Posted 15/07/21 10:18 AM Share Posted 15/07/21 10:18 AM @JETURBOso I'm looking at getting a set of 4 new fpv wheels for my 15 fgx xr6t to fit over my new 6 pot brembos. Question is if I get a staggered set 8 inch front, 9 inch rear and I get a puncture in a front tire, will the 9 inch wheel off the back fit the front? I could use the factory spare on the rear then to get home. There's only about a bit over half an inch room between the stock front tire and the suspension arm that goes up and over the tire. Or do I have to buy 8 inch all round? Thanks Link to comment Share on other sites More sharing options...
Slowxr6t Member 516 Member For: 5y 4m 21d Location: New zealand Posted 17/07/21 01:43 AM Share Posted 17/07/21 01:43 AM Does anyone out there know the answer to this? Link to comment Share on other sites More sharing options...
Slowxr6t Member 516 Member For: 5y 4m 21d Location: New zealand Posted 20/07/21 08:53 AM Share Posted 20/07/21 08:53 AM Can any you guys online at moment help with my question? Cheers Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,303 Member For: 16y 15d Gender: Male Location: Melbourne Posted 20/07/21 09:15 AM Share Posted 20/07/21 09:15 AM clearly nobody who's read it has the answer... I don't. 1 Link to comment Share on other sites More sharing options...
bossmang FREAKY Donating Members 12,403 Member For: 14y 4m Gender: Male Location: Melbourne Posted 22/07/21 12:43 PM Share Posted 22/07/21 12:43 PM ask club fg they do crazy sh*t like that Link to comment Share on other sites More sharing options...
Gurinderb233 New Member 1 Member For: 2y 8m 1d Posted 24/08/21 08:17 AM Share Posted 24/08/21 08:17 AM Hey Guys! I was just wondering if anyone has run 19x10.5 +22 for the rear set on a FG, and if you have what things did you have to do in order for the right fitment. My car is on SSSL on the rear and SSL on the front so Im just need to know before I buy the rims. Link to comment Share on other sites More sharing options...
SydCrazi Member 141 Member For: 13y 5m 9d Gender: Male Location: NSW Posted 21/11/21 10:29 AM Share Posted 21/11/21 10:29 AM FG G6ET MK2 Standards are 245/35 R19. I have no idea of the offset? Looking at rims that are 19 x8.5 +36 Any brainiac know if that's an exact match? Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,303 Member For: 16y 15d Gender: Male Location: Melbourne Posted 21/11/21 10:06 PM Share Posted 21/11/21 10:06 PM factory rims are all +36.5 offset (except for rare staggered ones), but you can confirm the specifics here -> https://www.wheel-size.com/size/ford/falcon/ Use willtheyfit to see the difference. They'll definitely fit as it's such a minor change, but they are slightly differently positioned as compared to factory. e.g. https://www.willtheyfit.com/index.php?width=245&aspect=35&diameter=19&wheelwidth=8&offset=36.5&width2=245&aspect2=35&wheel_size=19&wheel_width=8.5&offset2=36 Link to comment Share on other sites More sharing options...
SydCrazi Member 141 Member For: 13y 5m 9d Gender: Male Location: NSW Posted 22/11/21 12:48 AM Share Posted 22/11/21 12:48 AM Thanks @k31th much appreciated Link to comment Share on other sites More sharing options...
PookeyMaster Donating Members 1,531 Member For: 13y 4m 6d Gender: Male Location: Parramatta, NSW Posted 09/02/22 02:39 PM Share Posted 09/02/22 02:39 PM Looking for a sanity check on rims and tyres. Suspension height is basically the same as stock and I have no real desire to roll the guards. Front 20x9.0 +40 w/ 265/35R20 Compared with stock this will poke out 9.2mm which should be fine but will also sit 16.2mm closer to the suspension. Is the later going to be a problem and rub? Rear 20x10.0 +45 w/ 305/30R20 Compared with stock this will poke out 16.9mm which I think should also be fine. The big question is the suspension, these would sit 33.9mm closer and I believe the stock gap is ~40mm so I'm not sure that 6.1mm is enough margin once you account for 305 width tyres... Link to comment Share on other sites More sharing options...
