jimmks New Member 10 Member For: 4y 7m 6d Posted 23/02/21 09:44 PM Share Posted 23/02/21 09:44 PM Is that all it is a 2mm difference, is that sitting more inside or more outside towards the guard Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,238 Member For: 15y 11m 18d Gender: Male Location: Melbourne Posted 23/02/21 10:56 PM Share Posted 23/02/21 10:56 PM My apologies, stock is +36.5 on the front and +28.5 on the rear for the ones that have the staggered offset (argents, primarily), so this is actually 8mm difference, not 2mm like I was thinking haha, but it still doesn't make any difference to fitment. Adding more to the "positive" offset means the rim sits further inside the guard as the "mounting point" is moved in a positive direction from the centre of the rim which results in the rim itself being moved in the direction of the diff because the mounting point in reality doesn't move. Conversely, removing offset means the rim starts to "poke out" more. e.g. -20 offset will poke hugely, +40 offset will be well inside the guard and potentially fouling on suspension components (unless you get big fat width wheels that compensate for the loss/gain of offset in a certain direction, suspension or guard-wise) Link to comment Share on other sites More sharing options...
jimmks New Member 10 Member For: 4y 7m 6d Posted 24/02/21 02:37 AM Share Posted 24/02/21 02:37 AM Cheers mate, so I won't have an issue maybe running a 255 wide instead of the 245 wide ,so are these actually called a staggered set ,considering they are all 8 inch wide . Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,238 Member For: 15y 11m 18d Gender: Male Location: Melbourne Posted 24/02/21 03:00 AM Share Posted 24/02/21 03:00 AM staggered is just a way to say the front offset is different to the rear (or sometimes in rare cases just the width difference), that's all... and yes, 255;s fit fine on a 8" rim but you wouldn't want to go any wider than that and they'll have a bit of rubber overhang on the edges of the rim and it's up to you to care about that from an aesthetic point of view. Link to comment Share on other sites More sharing options...
jimmks New Member 10 Member For: 4y 7m 6d Posted 24/02/21 08:18 AM Share Posted 24/02/21 08:18 AM So the 8mm difference, will sit closer to the diff(inside ) ,will this leave a funny look from the guard to the rim itself, I heard they did this for better handling or was it just for rear brembos ,I did have a set of argents on my f6 before ,from memory the bloke that sold me them said they came of a bf gt ,I do remember fitting them with numbers labelled with sticky tape for front and backs as I bought them of a friend Link to comment Share on other sites More sharing options...
jimmks New Member 10 Member For: 4y 7m 6d Posted 10/03/21 10:14 PM Share Posted 10/03/21 10:14 PM This is it 28.5 offset 1 Link to comment Share on other sites More sharing options...
Slowxr6t Member 512 Member For: 5y 3m 24d Location: New zealand Posted 27/03/21 07:16 AM Share Posted 27/03/21 07:16 AM Hi guys, Im looking to upgrade my 2015 fgx xr6t front calipers to brembo 6 pistons. I need fpv wheels to clear them. I have the opportunity to buy a set of 18 inch BA GT wheels for a pretty good price. The guy says they clear 4 and 6 piston calipers but just wanted to check up with you blokes first before I part with my cash. Does anyone know? Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,238 Member For: 15y 11m 18d Gender: Male Location: Melbourne Posted 27/03/21 07:32 AM Share Posted 27/03/21 07:32 AM all FPV rims clear brembo's Link to comment Share on other sites More sharing options...
Slowxr6t Member 512 Member For: 5y 3m 24d Location: New zealand Posted 27/03/21 07:54 AM Share Posted 27/03/21 07:54 AM Awesome thanks keith Link to comment Share on other sites More sharing options...
Slowxr6t Member 512 Member For: 5y 3m 24d Location: New zealand Posted 27/03/21 08:14 AM Share Posted 27/03/21 08:14 AM My stock wheels are 19inch, if I go to 18 inch wheels will that mess up abs sensors or anything ? Link to comment Share on other sites More sharing options...
