Fg Offsets And Tyre Questions
Dillz
  • A much better forum
  • Silver Donating Members
  • Member For: 15y 8m 27d
Maybe on the rear? On the fronts it would stick out like dogs balls...
And no insurance company would cover you with zero offset...
  • 3 weeks later...
  • Member For: 13y 1m
Depends what offset you run. A 10 inch wide with anything around +30 should clear. I run a 19x10 + 15 and they just clear however there is ridiculous amounts of space on the inside. Also just to let any one know you will not be able to get rear fg guards rolled/pumped any more then a few mm. I'm a panel beater by trade and tried every trick in the book and without serious mods the quarters will not hold. Had a porta power pumping mine out to the point where we could see the quarters beginning to crease and they returned to virtually the same spot.
  • Like 2
  • Member For: 13y 8m
Thanks guys..
+38 will certainly fit
Im running 10 with +30 at the moment. But moving to +40 will sit the tyre further in and lose some of that flush look I was trying to achieve. Have a look at Wagnmans post.. that's just perfection! +35 !!
Thanks again.. Ill just have to sit down and nut this one out I guess
Cheers..
Guest XR09
  • Guests
I have a 42 rear offset with 19 x 275 and have never scrubbed or had to have the lip....what lip done on my FG.
4 blokes, 4 golf kits and getting along a crappy road and no scrape. Even hitting the inside curb at a fair rate.
I do run a 35cm ride height though so I have a bit more margin than a lot on here.
  • Member For: 15y 4m 28d
Looking at the following (if my understanding of offsets is correct) but want to make sure they will fit and look good.
20x8.5 +30 front with 245's
20x9.5 +38 rear with 275's
Can you fit a 20x10 with a 285 under the ass?
