Worm A much better forum Silver Donating Members 3,808 Member For: 15y 9m 2d Gender: Male Location: Victoria Posted 17/08/11 09:19 PM Share Posted 17/08/11 09:19 PM Maybe on the rear? On the fronts it would stick out like dogs balls...And no insurance company would cover you with zero offset... Link to comment Share on other sites More sharing options...
jimmixr Donating Members 686 Member For: 13y 8m 6d Posted 06/09/11 09:11 PM Share Posted 06/09/11 09:11 PM Hey guys..Thinkink of stepping up to 20's on my FG sedan. Fronts are 8.5x20 +35 and rears 20x10 +40.. How do you think theyll sit.. especially the rears? I want them as flush as possibleCheers Link to comment Share on other sites More sharing options...
Dillz Three pedals are better then two.. Donating Members 15,637 Member For: 16y 10m 30d Gender: Male Location: Melbourne Posted 07/09/11 08:32 AM Author Share Posted 07/09/11 08:32 AM 10's will probably require guard rolling wont they? Link to comment Share on other sites More sharing options...
JET50T Donating Members 152 Member For: 13y 1m 5d Gender: Male Location: Castle Hill Posted 07/09/11 10:56 AM Share Posted 07/09/11 10:56 AM Depends what offset you run. A 10 inch wide with anything around +30 should clear. I run a 19x10 + 15 and they just clear however there is ridiculous amounts of space on the inside. Also just to let any one know you will not be able to get rear fg guards rolled/pumped any more then a few mm. I'm a panel beater by trade and tried every trick in the book and without serious mods the quarters will not hold. Had a porta power pumping mine out to the point where we could see the quarters beginning to crease and they returned to virtually the same spot. 2 Link to comment Share on other sites More sharing options...
Dillz Three pedals are better then two.. Donating Members 15,637 Member For: 16y 10m 30d Gender: Male Location: Melbourne Posted 07/09/11 11:11 AM Author Share Posted 07/09/11 11:11 AM +38 should be ok then. Link to comment Share on other sites More sharing options...
jimmixr Donating Members 686 Member For: 13y 8m 6d Posted 07/09/11 08:38 PM Share Posted 07/09/11 08:38 PM Thanks guys..+38 will certainly fitIm running 10 with +30 at the moment. But moving to +40 will sit the tyre further in and lose some of that flush look I was trying to achieve. Have a look at Wagnmans post.. that's just perfection! +35 !!Thanks again.. Ill just have to sit down and nut this one out I guessCheers.. Link to comment Share on other sites More sharing options...
Guest XR09 Guests Posted 08/09/11 02:54 AM Share Posted 08/09/11 02:54 AM I have a 42 rear offset with 19 x 275 and have never scrubbed or had to have the lip....what lip done on my FG.4 blokes, 4 golf kits and getting along a crappy road and no scrape. Even hitting the inside curb at a fair rate.I do run a 35cm ride height though so I have a bit more margin than a lot on here. Link to comment Share on other sites More sharing options...
AirStrike Donating Members 387 Member For: 15y 5m 3d Gender: Male Posted 13/09/11 10:49 AM Share Posted 13/09/11 10:49 AM Looking at the following (if my understanding of offsets is correct) but want to make sure they will fit and look good.20x8.5 +30 front with 245's20x9.5 +38 rear with 275'sCan you fit a 20x10 with a 285 under the ass? Link to comment Share on other sites More sharing options...
Tocchi Sandtrap Motorsport Donating Members 2,055 Member For: 15y 5m Gender: Male Location: Perth Posted 14/09/11 03:45 AM Share Posted 14/09/11 03:45 AM safe as houses! Link to comment Share on other sites More sharing options...
Pazzo Donating Members 11,132 Member For: 13y 6m 2d Gender: Male Posted 14/09/11 05:05 AM Share Posted 14/09/11 05:05 AM What wheels Dillz, spill it. Link to comment Share on other sites More sharing options...
