AlexTT2006 New Member 4 Member For: 7y 6m 20d Posted 23/11/16 09:17 AM Share Posted 23/11/16 09:17 AM hi everyone having one of those days where I should of stayed in bed !! I have spent the last 1.5 hours on the internet trying to find with aftermarket performance parts fit both the TT and the XR6T, there is alot of used XR6 aftermarket bolt on goodies for sale and hardly any TT parts :( Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 10m 18d Gender: Male Location: Adelaide Posted 23/11/16 09:31 AM Share Posted 23/11/16 09:31 AM (edited) What exactly are you after as yes some share both platforms and others will be specific any intake,intercooler kits,exhausts will be TT specific injectors,fuel rails,turbos,valvesprings will be shared as a start Edited 23/11/16 09:31 AM by JETURBO 1 Link to comment Share on other sites More sharing options...
TaHa Member 948 Member For: 15y 10m 26d Gender: Male Posted 25/11/16 02:15 PM Share Posted 25/11/16 02:15 PM Plazmaman under battery intake does fit the TT. intercooler stuff is a bit more custom by easily can be made by buying off the shelf parts Link to comment Share on other sites More sharing options...
Para045 Member 35 Member For: 14y 7m 27d Gender: Male Location: Perth Posted 25/08/18 08:26 AM Share Posted 25/08/18 08:26 AM (edited) On 23/11/2016 at 5:17 PM, AlexTT2006 said: hi everyone having one of those days where I should of stayed in bed !! I have spent the last 1.5 hours on the internet trying to find with aftermarket performance parts fit both the TT and the XR6T, there is alot of used XR6 aftermarket bolt on goodies for sale and hardly any TT parts :( Yeah it's something I've often wondered as well? I have a 12 XR6T and the missus has an 07 Terra Turbo Ghia and recently we had a situation where the head on her TTG corroded out around the #4 sparkplug hole and was causing it to misfire Our mechanic was initially worried as he called around and no one had heard of the head on a TT needing replacing let alone had one and it was only after lots of phone calls that he found out that the TT and the XR6T heads were the same I knew the turbo side of things were different but was honestly surprised the heads were the same Again a few years back we had an issue where the oil light was coming on and after some research on here worked out that it was related to this little inline filter which apparently would get clogged and on the Falcons wasn't routed the same and you didn't know it was clogged till the turbo starved of oil and junked itself It's something I'll have to keep an eye on but it'd be handy to know what parts generally not just aftermarket parts are interchangeable between the two Edited 25/08/18 08:27 AM by Para045 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,286 Member For: 16y 8d Gender: Male Location: Melbourne Posted 25/08/18 10:43 AM Share Posted 25/08/18 10:43 AM Yep, heads are the same. Bugger that it took you so long to find that information. Turbo is roughly the same, in terms of exhaust manifold, turbo itself. Just different dump pipe and air intake piping plus minor differences in the cooler piping. Yep, the same oil feed to the turbo as in the sedan models which is known to cause oil starvation when the filter gets blocked. Again, bugger that you had to find that out the hard way. Link to comment Share on other sites More sharing options...
