joshua1396 New Member 8 Member For: 8y 10m 26d Posted 23/08/16 03:43 AM Share Posted 23/08/16 03:43 AM Hi all,So I recently picked up a Manual BF MK2.5 XR6T with 140000 on the clock. While I know this is high kms it was a good price which I couldn't resist. I have a few questions regarding the naintainenece etc.1. I'm going to do a full service of the car soon (oils, fluids, filters etc) so what would be recommended on a turbo of this age? The gearbox is a bit sticky so I'm going to do a service on that.2. How can I check the health of the engine? I don't want to give it a bootfull until I know how healthy it is.3. Is it true that the bf mk2.5 engine has similar internals to the typhoon engine? If so what parts?4. The gearbox is making a roll over noise (apparently common on these gearboxes) should I be worried or is this normal?Any more tips just let us knowThanks! Link to comment https://www.fordxr6turbo.com/forum/topic/92353-bf-turbo-help/ Share on other sites More sharing options...
HellBara Member 44 Member For: 10y 7m 22d Gender: Male Location: Central Coast Posted 23/08/16 05:52 AM Share Posted 23/08/16 05:52 AM Is it Red ? 1 Link to comment https://www.fordxr6turbo.com/forum/topic/92353-bf-turbo-help/#findComment-1608711 Share on other sites More sharing options...
joshua1396 New Member 8 Member For: 8y 10m 26d Posted 23/08/16 06:01 AM Author Share Posted 23/08/16 06:01 AM Why does that matter? Link to comment https://www.fordxr6turbo.com/forum/topic/92353-bf-turbo-help/#findComment-1608712 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 17y 1m 18d Gender: Male Location: Adelaide Posted 23/08/16 09:52 AM Share Posted 23/08/16 09:52 AM Car colour is dependent on service requirements...... 3 Link to comment https://www.fordxr6turbo.com/forum/topic/92353-bf-turbo-help/#findComment-1608754 Share on other sites More sharing options...
BAXRTUTE Gold Donating Members 2,639 Member For: 9y 3m 1d Posted 23/08/16 10:06 AM Share Posted 23/08/16 10:06 AM (edited) Hahaha Green cars are more eco friendly ive been told Edited 23/08/16 10:08 AM by BAXRTUTE 1 Link to comment https://www.fordxr6turbo.com/forum/topic/92353-bf-turbo-help/#findComment-1608755 Share on other sites More sharing options...
skidxr6t skids Donating Members 2,754 Member For: 12y 6m 20d Gender: Not Telling Posted 23/08/16 10:24 AM Share Posted 23/08/16 10:24 AM 6 hours ago, joshua1396 said: regarding the naintainenece welcome to the forum, 1. 10w-40 I used last, I think all good here long as its synthetic (cuz the turbo heats the f^ck out of it) and the last number is -40. might put in a 5w-40 next myself. used a ryco filter. 2. give it a boot after ya done the oil change and you've driven it normally for ten minutes to warm it up properly. cmon rip a skid, it's australia. 3. stronger rods and idk what else 4. lightning strike silver has the least maintenance. you better hope your car is this colour Link to comment https://www.fordxr6turbo.com/forum/topic/92353-bf-turbo-help/#findComment-1608757 Share on other sites More sharing options...
ROB83R Member 1,632 Member For: 9y 1m 29d Gender: Not Telling Location: Radioactive wasteland Posted 24/08/16 11:10 AM Share Posted 24/08/16 11:10 AM (edited) 140k is just run in. Do your service. Change all the fluids and filters. Fuel filter is on the left chassis rail under the back seat/rear door area. The bolts are a c u next Tuesday to get out. There's threads here on it. The rest are easy. I use nulon full syn 10w40 and a ryco filter z516 is the one you want. I've got a k&n panel filter. I highly recommend getting an aftermarket oil feed line for your turbo if it hasn't been done yet. Here's why Plenty of kits floating about. I just picked one up for $110. After you've done all that if you're still unsure take it to your local tuner and get them to check it out for you. Where are you located? Edited 24/08/16 11:12 AM by ROB83R Link to comment https://www.fordxr6turbo.com/forum/topic/92353-bf-turbo-help/#findComment-1608879 Share on other sites More sharing options...
skidxr6t skids Donating Members 2,754 Member For: 12y 6m 20d Gender: Not Telling Posted 24/08/16 12:14 PM Share Posted 24/08/16 12:14 PM 59 minutes ago, ROB83R said: take it to your local tuner and get them to check it out for you. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/92353-bf-turbo-help/#findComment-1608887 Share on other sites More sharing options...
ROB83R Member 1,632 Member For: 9y 1m 29d Gender: Not Telling Location: Radioactive wasteland Posted 24/08/16 01:50 PM Share Posted 24/08/16 01:50 PM Zesty vingarette is my suggestion. $1 at Coles. Link to comment https://www.fordxr6turbo.com/forum/topic/92353-bf-turbo-help/#findComment-1608903 Share on other sites More sharing options...
