El Andrew Gold Donating Members 2,019 Member For: 9y 2d Gender: Male Location: Canberra ACT Posted 01/07/16 10:56 PM Share Posted 01/07/16 10:56 PM That's cylinder 3 misfire. Just to eliminate the possibility, I'd swap cylinder 3's coil and plug with another cylinder just to make sure there's not a fault with the new stuff. If the fault remains and follows the cylinder you moved that coil and plug to then that's your issue. Costs nothing to try. I only say that because I had a similar issue with my BA. My mechanic used cheap coils and so the problem remained. 1 Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 10m 25d Gender: Male Location: Adelaide Posted 01/07/16 10:59 PM Share Posted 01/07/16 10:59 PM Link to comment Share on other sites More sharing options...
It's just me New Member 10 Member For: 7y 9m 24d Posted 01/07/16 11:03 PM Author Share Posted 01/07/16 11:03 PM Ok thanks heaps, I will try the coil cylinder swap thingo, any idea which coils relate to which cylinder....... Link to comment Share on other sites More sharing options...
bamk2f6tornado Bronze Donating Members 777 Member For: 10y 4m 22d Gender: Male Location: Rockhampton Qld Posted 01/07/16 11:40 PM Share Posted 01/07/16 11:40 PM Barras are coil on top of plug so whip the coil cover off and you will realise how easy it is. There is no mistaking which one is for what cylinder Link to comment Share on other sites More sharing options...
It's just me New Member 10 Member For: 7y 9m 24d Posted 02/07/16 03:51 AM Author Share Posted 02/07/16 03:51 AM After taking coil cover off I see the mechanic has only replaced the front 3 coils and not the back 3 ?He has Used aftermarket? VDO crap........ I could only get my hands on 1 engine coil today no one had them in stock........ Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,303 Member For: 16y 15d Gender: Male Location: Melbourne Posted 02/07/16 06:46 AM Share Posted 02/07/16 06:46 AM Well that's likely your problem. Never use mismatching coils. Link to comment Share on other sites More sharing options...
It's just me New Member 10 Member For: 7y 9m 24d Posted 03/07/16 01:32 AM Author Share Posted 03/07/16 01:32 AM Thanx everyone for your help , The ticking sound happens even when the engines off but ignition left on........ Will get 6 new coils on Monday and install see what happens, all failing that I will take it to real dyno in kipparing .......... Link to comment Share on other sites More sharing options...
Culbert New Member 2 Member For: 4y 8m 7d Posted 23/08/19 06:51 AM Share Posted 23/08/19 06:51 AM Hi mate. Im having the same problem with my car and have replaced all coils purchased from intune. Any more info of how you resloved this problem would be muchly appreciated. Thanks Link to comment Share on other sites More sharing options...
