It's just me New Member 10 Member For: 7y 8m 27d Posted 01/07/16 10:11 AM Share Posted 01/07/16 10:11 AM (edited) Car is running really rough misfiring "popping" out exhaust on idle (similar to leads arcing) motor badly shuddering under acceleration then runs fine then coughs and splutters, then engine light flashes, engine light stays on, turns off , car runs ok, then starts playing up again, ok so far a service had all coils replaced and new spark plugs .default code said cylinder 3 misfire .............help please , 2012 95,000km ....... Edited 01/07/16 10:12 AM by It's just me Mistake Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,238 Member For: 15y 11m 18d Gender: Male Location: Melbourne Posted 01/07/16 10:20 AM Share Posted 01/07/16 10:20 AM timing chain skipped a tooth (or more) or coil driver failed in PCM Link to comment Share on other sites More sharing options...
It's just me New Member 10 Member For: 7y 8m 27d Posted 01/07/16 10:28 AM Author Share Posted 01/07/16 10:28 AM Thank u k31 , I'm hearing a consistent click noise every 10 seconds underneath the car on idle near cat almost the same as the click on some cars when the air con comes on ,on some cars........ Funny enough this all happened after driving on a dirt road the other day......... Coincidence I'm not sure Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,238 Member For: 15y 11m 18d Gender: Male Location: Melbourne Posted 01/07/16 10:37 AM Share Posted 01/07/16 10:37 AM a click near the cat could just be a collapsed cat... but could be a tick from further up the exhaust... is the tick coming from near the turbo itself? if it is, it's a head-manifold gasket or a turbo to dump gasket. I doubt it's related to driving on a dirt road unless you were using it to smash the limiter (which can cause timing chain/guide issues). Link to comment Share on other sites More sharing options...
It's just me New Member 10 Member For: 7y 8m 27d Posted 01/07/16 11:06 AM Author Share Posted 01/07/16 11:06 AM Ok that gives me something to work with, I'm also getting some knocking ( clunking) coming from under the car drivers side under load , hard enough to feel it thru the accelerator....... Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,238 Member For: 15y 11m 18d Gender: Male Location: Melbourne Posted 01/07/16 11:15 AM Share Posted 01/07/16 11:15 AM engine mount... but could be almost anything in the suspension. Link to comment Share on other sites More sharing options...
It's just me New Member 10 Member For: 7y 8m 27d Posted 01/07/16 11:28 AM Author Share Posted 01/07/16 11:28 AM Cheers , back to the mechanic for the forth time I go .......... Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,238 Member For: 15y 11m 18d Gender: Male Location: Melbourne Posted 01/07/16 11:30 AM Share Posted 01/07/16 11:30 AM where are you located? going to the right place is probably a better alternative than returning to the place that forced you to ask on here in the first place. Link to comment Share on other sites More sharing options...
It's just me New Member 10 Member For: 7y 8m 27d Posted 01/07/16 08:21 PM Author Share Posted 01/07/16 08:21 PM Queensland , Sunshine Coast , mods were done at real dyno in Brisbane , been taking it to my local mechanic though, so far only thing come up on the scan tool is misfire on cylinder 3 on startup , and a p1000 code something about going thru a cycle? Link to comment Share on other sites More sharing options...
It's just me New Member 10 Member For: 7y 8m 27d Posted 01/07/16 10:27 PM Author Share Posted 01/07/16 10:27 PM Ok Just ran the scan tool on it this morning code it's giving me is P0303........ Link to comment Share on other sites More sharing options...
