Rab WOT? Moderating Team 10,980 Member For: 11y 1m 25d Gender: Male Location: Frankston, 3199 Posted 21/03/19 01:49 PM Share Posted 21/03/19 01:49 PM Closed circuit Link to comment Share on other sites More sharing options...
masda74 To Loud Gold Donating Members 4,112 Member For: 12y 4m 20d Gender: Male Location: WA, Perth Posted 22/03/19 01:29 AM Share Posted 22/03/19 01:29 AM I was going to say, my brother is part of the overclockers Australia community and has been there for a while. admin on their discord channel. He said it makes no difference. I will say that changing the airflow direction should make a difference. I am going to change the back fan to suck air out instead of sucking fresh in air. I will then change the TOP Radiator fan direction from blowing air out of the case, to blowing it into the case. I think that might be where things will change. I set it up this way under the advise of my brother. I just suspect that is why the cpu is getting so hot. Link to comment Share on other sites More sharing options...
bloodycrashboy Feeling the Love :-) Bronze Donating Members 4,409 Member For: 11y 19d Gender: Male Location: Cairns Posted 22/03/19 02:30 AM Share Posted 22/03/19 02:30 AM 1 hour ago, masda74 said: I just suspect that is why the cpu is getting so hot. my CPU runs up to the high 50's when gaming, GPU high 40's to low 50's depending on what game with air con running and the temps are low 40's GPU and mid to high 40's CPU idle now GPU is 30 and CPU is 34 (ambient temp is 26) cos cold and raining in Cairns On 10/02/2019 at 4:25 PM, bloodycrashboy said: cos old bastard who thinks he knows computers................................................................. playing The Division 2 (thank's @Rab) temps after about 3/4 hour gameplay H2O the way to go @masda74 this was with the aircon running at 24° I have top radiator with fans on top of radiator sucking air out of the case front radiator, fans on outside of radiator blowing air into case 1 Link to comment Share on other sites More sharing options...
MBAF Bronze Donating Members 2,156 Member For: 7y 8m 4d Posted 22/03/19 04:42 AM Share Posted 22/03/19 04:42 AM (edited) 14 hours ago, bloodycrashboy said: sorry, I stand corrected @Rab is right 14 hours ago, Rab said: Closed circuit 1 rad v 2 is different. He has only one cooling surface so it won’t make any difference In my experience with 2 rads you get better cooling going from each heat source to a rad by more than 10c on my setup but what would I know.. Edited 22/03/19 04:43 AM by MBAF 1 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,291 Member For: 16y 9d Gender: Male Location: Melbourne Posted 22/03/19 04:53 AM Author Share Posted 22/03/19 04:53 AM maybe a youtuber has tested the 2 rad setup? or should? Link to comment Share on other sites More sharing options...
MBAF Bronze Donating Members 2,156 Member For: 7y 8m 4d Posted 25/03/19 01:07 AM Share Posted 25/03/19 01:07 AM I’m sure it probably has but there is plenty of people who have done it on the internet and posted results. Its a no brainer really if you look at it logically. Link to comment Share on other sites More sharing options...
.Stripes. All stock bar the k&n panel filter Silver Donating Members 8,061 Member For: 12y 1m 6d Gender: Male Location: Perth Posted 27/03/19 05:37 AM Share Posted 27/03/19 05:37 AM @k31th If I'm wanting to create an emulated Surface Pro-esq tablet environment on my work laptop so I can run our software on that simulated screen size to get layouts right etc...is Visual studio with the Microsoft Emulator for W10 the way to go? Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,291 Member For: 16y 9d Gender: Male Location: Melbourne Posted 27/03/19 05:39 AM Author Share Posted 27/03/19 05:39 AM I assume you're already on a windows machine, so you can just change the resolution of the screen you're currently on to match whatever device, if it's only resolution you're testing. If you're testing more than that, it gets complicated depending on which direction you want to go. Link to comment Share on other sites More sharing options...
.Stripes. All stock bar the k&n panel filter Silver Donating Members 8,061 Member For: 12y 1m 6d Gender: Male Location: Perth Posted 27/03/19 05:42 AM Share Posted 27/03/19 05:42 AM Ideally just resolution...but the surface has higher resolution than my machine haha. And I don't seem to have a resolution in the options that has the same aspect ratio 😬 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,291 Member For: 16y 9d Gender: Male Location: Melbourne Posted 27/03/19 05:47 AM Author Share Posted 27/03/19 05:47 AM well, you can run a virtual machine via "Windows Virtual PC" or "Hyper-V" (depending on the version of windows you're using) to get a VM of any resolution. Obviously if the resolution is bigger than your baseline, it'll require a considerable amount of scrolling to see it all, but it'll get the job done. Link to comment Share on other sites More sharing options...
