Guest Guests Posted 22/06/16 07:13 AM Share Posted 22/06/16 07:13 AM Yeah whats up? Link to comment Share on other sites More sharing options...
barnz Member 3,047 Member For: 10y 5m Gender: Male Location: Brisbane Posted 22/06/16 07:16 AM Share Posted 22/06/16 07:16 AM its really not that difficult and there are couple of different methods. Selecting the correct mobo, cpu and ram as well as knowing the limitations of the setup are key. I have an haswell i5 4570 non K at 3.6ghz and have short burst at 4gz. Yes it is actually possible to overclock a non K processor but the multipliers are limited. FSB method can be used but the reason intel didnt make them "k's" and leave the multipliers unlocked is they know they are unstable at higher clocks. From my understanding they dont manufactuer Ks and non Ks specifically its determined in testing if they will be suitible. Or they are the same cpu and they literally charge you a bucket load more for just leaving it unlocked...But I have genuinely found mine unstable past 4ghz at like 80c well before thermal throttling. If you want to go nuts like 8ghz you will need liquid nitrogen and its retarded. Good liquid cooler and correct parts will see a reasonable increase in clock speeds 2 Link to comment Share on other sites More sharing options...
Guest Guests Posted 22/06/16 07:18 AM Share Posted 22/06/16 07:18 AM On a side note hurry the fark up. Not sure how it downloaded 252 updates when I have it turned off :/ Link to comment Share on other sites More sharing options...
skidxr6t skids Donating Members 2,754 Member For: 11y 3m 23d Gender: Not Telling Posted 22/06/16 07:29 AM Share Posted 22/06/16 07:29 AM (edited) With my Z97 rig I initially had an intel G3258 (unlocked 3.5ghz dual core) for some fun and also cause it was only $90 got that upto 4.5ghz at 1.32v. I pushed it to 4.7ghz but I wasn't comfortable with the voltage. Current chip I didn't even touch the voltage for stable 4ghz, been like that for about 8 months. I need a bigger cooler and believe this chip is good for 4.2-4.4ghz. Currently runs corsair H55, this is a H110i that I want to fit but I was thinking of doing a custom watercooling setup with a triple 120mm radiator front mounted I need to dig up photos of @SteveR 's computer, quite like how he had to cut his case to fit the new graphics card and think he should show off his IT man handywork Edited 22/06/16 07:29 AM by johnxr6t 1 Link to comment Share on other sites More sharing options...
Guest Guests Posted 22/06/16 07:32 AM Share Posted 22/06/16 07:32 AM Yeah my ivy bridge was at 4.2ghz without doing anything other than a multiplyer on the standard boxed cooler. Ran like a dream. Built it for over clocking and never did apart from the msi auto overclock. Ivy bridge is old but gold Link to comment Share on other sites More sharing options...
bloodycrashboy Feeling the Love :-) Bronze Donating Members 4,409 Member For: 11y 19d Gender: Male Location: Cairns Posted 22/06/16 07:33 AM Share Posted 22/06/16 07:33 AM 28 minutes ago, Ford Freak said: anyone here good with over clocking? here are the basics http://www.pcworld.com/article/198882/overclocking_for_newbies.html Link to comment Share on other sites More sharing options...
luke187 Member 297 Member For: 10y 4m 13d Posted 22/06/16 08:37 AM Share Posted 22/06/16 08:37 AM Got my 4770k @ 4.8 with 1.28v 24/7, using an x61 nzxt kraken water cooler for the cpu. Overclocked everything ive owned since my celeron 300... like turning up the boost just nerdier and much less exciting. Can help if you need but the guides you'll find around are a better source of info 3 Link to comment Share on other sites More sharing options...
Guest Guests Posted 22/06/16 08:40 AM Share Posted 22/06/16 08:40 AM (edited) Overclocker forums are a good source too.. plenty of info on the interwebs Edit: 245 of 252 updates. Home stretch! Been going for like 6hrs:/ Edited 22/06/16 08:41 AM by mightbuyaford Link to comment Share on other sites More sharing options...
Guest Guests Posted 22/06/16 11:04 AM Share Posted 22/06/16 11:04 AM I think you will find the 6min mark exceptionally tasteful :D Link to comment Share on other sites More sharing options...
bossmang FREAKY Donating Members 12,403 Member For: 14y 3m 26d Gender: Male Location: Melbourne Posted 23/06/16 07:26 AM Share Posted 23/06/16 07:26 AM 22 hours ago, luke187 said: Got my 4770k @ 4.8 with 1.28v 24/7, using an x61 nzxt kraken water cooler for the cpu. Overclocked everything ive owned since my celeron 300... like turning up the boost just nerdier and much less exciting. Can help if you need but the guides you'll find around are a better source of info yer I have the i5 4690k. would like to try o/c for more boost when gaming now that im getting back into it. I think the graffix card is a gtx 960. just a cheap build. playing gta needs a boost ahahha Link to comment Share on other sites More sharing options...
