Cam timing solenoids
dayjunkie
  • Member For: 14y 11m 4d
Hey T junkies,
Anyone know if I can remove the 2 cam timing solenoids for cleany just by removing rocker cover and without removing the entire cam assembly,,,because that would really suck.
The cam assembly would be a real hassel to remove,  I just want to make certain the solenoids arent stickin or clogged, its 1 of the last checks to solve my ongoing intermittent 'Cam position Timing over-retard fault'.
  • Moar Powar Babeh
  • Member For: 18y 6m 27d
very easy to remove.
If you're lucky and have the early style with no retaining bracket they will slide out without removing the recover cover.
If you're getting cam timing faults codes and not came solenoid errors it's more likely a timing chain issue so it would pay to remove the rocker box either way to verify cam timing.
Thanks mate, pickin up a gasket now, im hoping solenoids unbolt and slide in and out without any complications.
Hope its not a chain, heard gotta drop engine to do, might be time to get another bank loan and put Atomic Short engine in.
Edited by dayjunkie
  • The Toxic Rocket
  • Member For: 13y 11m 26d
You're talking about the 2 in the front of the cover?
I had similar codes come up and one of the sensors has split, knocked it back together and problem fixed.
  • ...JD TUNING ADELAIDE...
  • Member For: 15y 10m 19d
21mm socket on the balancer bolt
remove the plugs,fans and go for gold until you see this
thanks mate, not sure how this is possible but my sprokets in that position are 180 degrees out to the the yellow links.  Sprokets in that position match balancer alignment though.
I had billet chain , pump gears, replaced 8 years ago so its possible that mechanic measured time from another angle.
Another crack it tomoz probably got another rotation left to spanner around...
