dayjunkie Member 20 Member For: 14y 11m 9d Gender: Male Location: QLD Posted 19/05/16 04:56 AM Share Posted 19/05/16 04:56 AM Hey T junkies, Anyone know if I can remove the 2 cam timing solenoids for cleany just by removing rocker cover and without removing the entire cam assembly,,,because that would really suck. Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 18y 7m 2d Gender: Male Location: Perth Posted 19/05/16 04:59 AM Share Posted 19/05/16 04:59 AM which but would really suck,,,,,,removing just the rocker cover or,,,,,,removing the cam assembly? either way rocker cover off only. Link to comment Share on other sites More sharing options...
dayjunkie Member 20 Member For: 14y 11m 9d Gender: Male Location: QLD Posted 19/05/16 05:25 AM Author Share Posted 19/05/16 05:25 AM The cam assembly would be a real hassel to remove, I just want to make certain the solenoids arent stickin or clogged, its 1 of the last checks to solve my ongoing intermittent 'Cam position Timing over-retard fault'. Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 18y 7m 2d Gender: Male Location: Perth Posted 19/05/16 05:27 AM Share Posted 19/05/16 05:27 AM very easy to remove. If you're lucky and have the early style with no retaining bracket they will slide out without removing the recover cover. If you're getting cam timing faults codes and not came solenoid errors it's more likely a timing chain issue so it would pay to remove the rocker box either way to verify cam timing. Link to comment Share on other sites More sharing options...
dayjunkie Member 20 Member For: 14y 11m 9d Gender: Male Location: QLD Posted 19/05/16 05:31 AM Author Share Posted 19/05/16 05:31 AM (edited) Thanks mate, pickin up a gasket now, im hoping solenoids unbolt and slide in and out without any complications. Hope its not a chain, heard gotta drop engine to do, might be time to get another bank loan and put Atomic Short engine in. Edited 19/05/16 05:38 AM by dayjunkie Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 18y 7m 2d Gender: Male Location: Perth Posted 19/05/16 05:54 AM Share Posted 19/05/16 05:54 AM Engine does not need to be removed to replace the Timing gear. Link to comment Share on other sites More sharing options...
Trent0 The Toxic Rocket Donating Members 574 Member For: 14y Gender: Male Location: Brisbane Posted 19/05/16 08:16 AM Share Posted 19/05/16 08:16 AM You're talking about the 2 in the front of the cover? I had similar codes come up and one of the sensors has split, knocked it back together and problem fixed. Link to comment Share on other sites More sharing options...
dayjunkie Member 20 Member For: 14y 11m 9d Gender: Male Location: QLD Posted 19/05/16 10:43 AM Author Share Posted 19/05/16 10:43 AM Any tips on turning the harmonic balancer by hand to see if the timing chain matches up,or is it as straight forward as I that Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 10m 25d Gender: Male Location: Adelaide Posted 19/05/16 10:52 AM Share Posted 19/05/16 10:52 AM 21mm socket on the balancer bolt remove the plugs,fans and go for gold until you see this 1 Link to comment Share on other sites More sharing options...
dayjunkie Member 20 Member For: 14y 11m 9d Gender: Male Location: QLD Posted 19/05/16 03:27 PM Author Share Posted 19/05/16 03:27 PM thanks mate, not sure how this is possible but my sprokets in that position are 180 degrees out to the the yellow links. Sprokets in that position match balancer alignment though. I had billet chain , pump gears, replaced 8 years ago so its possible that mechanic measured time from another angle. Another crack it tomoz probably got another rotation left to spanner around... Link to comment Share on other sites More sharing options...
