Duane343 New Member 14 Member For: 8y 8m 23d Posted 14/05/16 09:11 AM Share Posted 14/05/16 09:11 AM Hi guys this is my first post on here, I bought a 2011 fg xr6t ute, manual, last year. I noticed a when I when I was changing gears a loud air blow off noise recently and when I popped the hood the big pipe that says turbo intercooler that runs over the engine (not exactly a pro with motors lol) had popped off. Easy to put back on but I noticed a fair bit of oil in the pipe and it had leaked onto the top of the motor. Can someone please help, is this anything to worry about and is it ok to drive as is? Link to comment Share on other sites More sharing options...
MattyP MattyP Cruise Control 6,317 Member For: 11y 11m 19d Gender: Male Location: Central Coast Posted 14/05/16 09:17 AM Share Posted 14/05/16 09:17 AM Is it using oil? Link to comment Share on other sites More sharing options...
Duane343 New Member 14 Member For: 8y 8m 23d Posted 14/05/16 09:18 AM Author Share Posted 14/05/16 09:18 AM Nah oil is still full in engine Link to comment Share on other sites More sharing options...
MattyP MattyP Cruise Control 6,317 Member For: 11y 11m 19d Gender: Male Location: Central Coast Posted 14/05/16 09:42 AM Share Posted 14/05/16 09:42 AM Should be fine Most cars have a little blow by Just keep an eye on your oil and pull be fine Link to comment Share on other sites More sharing options...
Duane343 New Member 14 Member For: 8y 8m 23d Posted 14/05/16 09:53 AM Author Share Posted 14/05/16 09:53 AM Ok thanks mate. I probably sound like a total noob to you guys. Cant wait to do my first round of upgrades and learn more about it bit funds are a bit tight atm. Any help is much appreciated 1 Link to comment Share on other sites More sharing options...
FGMKII Member 193 Member For: 10y 3m 12d Gender: Male Location: Western Sydney Posted 14/05/16 10:02 AM Share Posted 14/05/16 10:02 AM You will see one of the breather lines from the top of the engine cover going into the crossover pipe and it is there (as stated above) because the engines "naturally" do let some oil by and for emissions purpose it goes back through the system to be burnt off. If you take off any intercooler pipes in future you will probably notice a bit in there too. Way around it is to buy a catch can if you wanted to but not needed. Link to comment Share on other sites More sharing options...
Duane343 New Member 14 Member For: 8y 8m 23d Posted 14/05/16 10:23 AM Author Share Posted 14/05/16 10:23 AM Thanks man, that's put my mind at ease I noticed that breather line. The oil probably hasn't been burning off because the crossover pipe was disconnected for a bit. Link to comment Share on other sites More sharing options...
Duane343 New Member 14 Member For: 8y 8m 23d Posted 14/05/16 10:35 AM Author Share Posted 14/05/16 10:35 AM I meant "that's". how does it get burned off Link to comment Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 16y 4m 30d Gender: Male Location: Probably above atmospheric pressure Posted 14/05/16 11:36 AM Share Posted 14/05/16 11:36 AM You using a phone to post? Might explain the ' being replaced, you're not the only one it affects so don't worry about it. When the oil is sent back into the intake pipe of the crossover (bit on top of engine) it gets sucked in to the turbo by the compressor, then passes through the intercooler and in to the intake manifold. No prizes for guessing where it goes after that hahaha Link to comment Share on other sites More sharing options...
FGMKII Member 193 Member For: 10y 3m 12d Gender: Male Location: Western Sydney Posted 14/05/16 11:37 AM Share Posted 14/05/16 11:37 AM By being sucked back into the system through the turbo and going through the engine. As the joins and pipes etc don't sit completely flush, that is where the liquid build up usually settles. 1 Link to comment Share on other sites More sharing options...
