T-Rex Donating Members 98 Member For: 12y 3m Gender: Male Posted 20/04/16 10:19 AM Share Posted 20/04/16 10:19 AM Guys, Put in slave cylinder with the remote line - the absolute nightmare won't bleed properly. All I can make out is that the nipple is leaking through the thread and sucking air back that way as well. I started bleeding it old school and it seemed to be working however I've had enough of it for tonight and will try again tomorrow maybe. Does anyone know a way to stop the nipple doing that so I can use a one man bleeder? Is it a faulty nipple? Link to comment Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,751 Member For: 12y 9m 4d Posted 20/04/16 11:33 AM Share Posted 20/04/16 11:33 AM Nah there just a *beep* to bleed. Ivr only ever got them to bleed by gravity feed for a while, then just go back and forth like a million times on the pedal really fast. Like real fast. . Just move the pedal a very little bit. Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 18y 7m 1d Gender: Male Location: Perth Posted 20/04/16 11:48 AM Share Posted 20/04/16 11:48 AM Thread tape on the nippld threads. tehehehe nipple threads In all seriousness, you'll get much better results with 2 people. Do this Crack Nipple Helper pushes pedal 2/3 or travel Close Nipple Release pedal Top up fluid Rinse Repeat The pump/pump "crack it"... "let got" close nipple technique doesn't work too well with this system Link to comment Share on other sites More sharing options...
turboknapp Donating Members 783 Member For: 17y 1m 1d Gender: Male Location: perth w.a Posted 20/04/16 11:53 AM Share Posted 20/04/16 11:53 AM What about auto bleeders Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 18y 7m 1d Gender: Male Location: Perth Posted 20/04/16 12:21 PM Share Posted 20/04/16 12:21 PM There's definitely a joke in there about all women being auto bleeders but I'm not touching it. 1 Link to comment Share on other sites More sharing options...
T-Rex Donating Members 98 Member For: 12y 3m Gender: Male Posted 20/04/16 01:03 PM Author Share Posted 20/04/16 01:03 PM That's guys, the two man seemed like it was working but the missus was chucking frownys about having to help so I'll have to finish doing it with a mate I actually had the thread tape out and was about to try it but the fluid was going everywhere and if I resort to that I'll just let it drain out before doing it rather than battling with it! Link to comment Share on other sites More sharing options...
eff xr6t Member 569 Member For: 10y 6m 26d Posted 20/04/16 01:13 PM Share Posted 20/04/16 01:13 PM Undo the bleed nipple get a syringe and suck the fluid through till it runs freely flush 2-3 fills of the resivoir through it then screw the nipple back in and tighten. Get in car and pump the pedal like a mother focker till it pulls a good pedal. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,303 Member For: 16y 15d Gender: Male Location: Melbourne Posted 21/04/16 01:12 PM Share Posted 21/04/16 01:12 PM Ralph, as usual, got it right sucks that your missus couldn't follow instructions... also approve of the "chucking frowny's" terminology... not sure why it made me laugh... Link to comment Share on other sites More sharing options...
T-Rex Donating Members 98 Member For: 12y 3m Gender: Male Posted 23/04/16 04:53 AM Author Share Posted 23/04/16 04:53 AM Ahhhh so I subbed a mate in, bled in no time! Final diagnosis..... The piston isn't disengaging the clutch... They were like for like so I can only assume it's dead on arrival or something of that sort. I'll be pulling the box tonight to put the old one back in, anyone have any helpful insight if It could be something else I've overlooked before I get under there??? Pedal feel is normal (now it's bled) but in gear starts with clutch in it tries to move ie on grab point Link to comment Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,751 Member For: 12y 9m 4d Posted 23/04/16 06:51 AM Share Posted 23/04/16 06:51 AM You need to measure your uncompressed height of the slave and keep them the same. Some have a spacer others don't Link to comment Share on other sites More sharing options...
