NA_TURBO Member 532 Member For: 8y 6m 16d Gender: Male Location: Mildura Posted 21/11/19 09:48 AM Author Share Posted 21/11/19 09:48 AM More parts arrived today, waiting for some stuff to come from the USA so not sure how long that will take, then can get the box built.TCE will be making a custom torque converter to suit. Probably won't have the box ready for another 3 or 4 months depending on the transmission builder and how lazy I am getting the car modified and everything fitted. 1 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,302 Member For: 16y 14d Gender: Male Location: Melbourne Posted 21/11/19 09:50 AM Share Posted 21/11/19 09:50 AM getting fully serious now Link to comment Share on other sites More sharing options...
NA_TURBO Member 532 Member For: 8y 6m 16d Gender: Male Location: Mildura Posted 21/11/19 09:53 AM Author Share Posted 21/11/19 09:53 AM Yep, do it right the first time and build it stronger than required saves lots of headaches and money down the track. All these parts are rated to 1500hp+ so shouldn't have to worry about it again Link to comment Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,751 Member For: 12y 9m 3d Posted 21/11/19 09:59 AM Share Posted 21/11/19 09:59 AM Doing/ done thrust bearing work for the glide? Link to comment Share on other sites More sharing options...
NA_TURBO Member 532 Member For: 8y 6m 16d Gender: Male Location: Mildura Posted 21/11/19 10:09 AM Author Share Posted 21/11/19 10:09 AM Yep done the 360 degree thrust bearing Cars been in the shed with no engine for 2 months already and most I've done is the main bearings and electric power steering haha been too lazy and now it's getting too hot 1 Link to comment Share on other sites More sharing options...
NA_TURBO Member 532 Member For: 8y 6m 16d Gender: Male Location: Mildura Posted 23/11/19 08:46 AM Author Share Posted 23/11/19 08:46 AM Had a crack at fitting the shifter today, made some mounting brackets out of some 3mm thick aluminum right angle plate. Had to play around a little with the height to get the shifter to sit where I wanted it too. Came up alright I reckon.Used the 6 speed surround and modified it to fit snug and even got the boot on it too. 5 Link to comment Share on other sites More sharing options...
NA_TURBO Member 532 Member For: 8y 6m 16d Gender: Male Location: Mildura Posted 27/11/19 08:08 AM Author Share Posted 27/11/19 08:08 AM Got more parts today, nearly ready to start assembling the box. Still waiting for the bellhousing though and pump gears and billet servo should be here from the states this week hopefully. Got a Reid roller bearing extension housing, Sonnax billet roller bearing governor support, 3 inch deep transmission pan, TCI Kevlar extra wide bands and Sonnax Extreme input shaft. And Sonnax 10 clutch high drum 2 Link to comment Share on other sites More sharing options...
NA_TURBO Member 532 Member For: 8y 6m 16d Gender: Male Location: Mildura Posted 10/12/19 07:56 AM Author Share Posted 10/12/19 07:56 AM Pumps been modified, new turbo 400 stator tube pressed in, billet gears and PTFE bush. Parts from Summit showed up so it's ready to bolt together as soon as the bellhousing rocks up. 3 Link to comment Share on other sites More sharing options...
NA_TURBO Member 532 Member For: 8y 6m 16d Gender: Male Location: Mildura Posted 12/12/19 09:11 AM Author Share Posted 12/12/19 09:11 AM Getting there slowly... *mod note* pics removed as they got corrupted. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,302 Member For: 16y 14d Gender: Male Location: Melbourne Posted 12/12/19 09:14 AM Share Posted 12/12/19 09:14 AM wtf happened to those pics... Link to comment Share on other sites More sharing options...
