My Bf Xr6 Na Engine With Turbo
  • 3 weeks later...
  • Member For: 8y 5m 21d
So my Davies Craig electronic fan controller died again, third one. Adjusting button seems to get stuck the dies. So I made my own relay system to control both fans from the cars ecu. Mine only came with a single fan, hence why I've made my own relay setup.
  • 2 weeks later...
an Eboost even with no RPM reference can still be set up to deliver a much cleaner power generation display that that graph above
Soooooooo seems like a certain somebody didn't have the settings on the eBoost set properly.
So after the tune the eBoost settings were SP - 47 GP - 7.2psi
Have since learned that the Gate Pressure should be roughly 3 psi below the desired boost pressure and the set point adjusted to steady the boost. I've changed mine to SP 17 and GP 11.5psi.
Power comes on a little later in the revs by only about 200rpm, but not as strong and seems to keep the power to redline. It used to rattle a little if accelerated too hard in the wrong gear but it's stopped that now.
Need to work out how to give the eBoost an rpm signal and also to activate my intercooler sprayers lol
I was just trying to keep thing's local instead of traveling 450kms to Adelaide for tuning. I have no faith in my car traveling 900km round trip and doing god knows how many dyno runs. I'd be screwed if we got stuck over there..
  • ...JD TUNING ADELAIDE...
  • Member For: 15y 9m 27d
It’s only “Dura” lol not far at all, been there a few times myself, I wouldn’t hand your car back without it being reliable buddy haha
just ask George @fun001 who came from NSW for a Tune ;)
seriously though if you've heard it “rattle” its far from tuned correctly !
