k31th less WHY; more WOT Site Developer 28,303 Member For: 16y 15d Gender: Male Location: Melbourne Posted 22/11/15 11:25 PM Share Posted 22/11/15 11:25 PM yer hes pretty gaywith the amount of dribble on this forum from you , you could have already made a thread with all the answers everyone's asking and been done with it ages ago. my2centsas explained hnyar -> http://www.fordxr6turbo.com/forum/topic/91399-k13ths-car/#entry1570678-- it's just a ton easier to type a short response than a long one. Cool colour f6, hope it gets back on the road where it belongs without costing too much, although it sounds like you are at the stage where nothing else will happen without opening your wallet wideCheers mate, $$ yep.They need to be parallel to provide less restriction, series doesnt work the same, 3 high flows in series may get the emissions effect your after but will only flow as well as one, or the most restrictive one1 200cpi "high flow" (maybe for an N/A car LOL ) catalytic converter "should" be sufficient for a low power tune.Best colour that came out on the BA's!Keith, couldn't you just get two tunes for the car? One that passes emissions and another for 'track work' for those times you want to give it a bit of a boot?Is there much lenience in an E85 emission compared to 98? Obviously the clutch is on its last legs but a weak as pi$$ tune would at least get you mobile.Yep, the tune box will hold 10 tunes, these days (XCAL3) so of course that's what I'll be doing... With regard to E85, I believe E85 has "other" emissions issues and they'll be able to easily tell you're trying to fool the test by using a different fuel and they'd probably auto-fail you. 98 or nothing, it seems, from my research.It's the cat converter that's the problem - a high-flow cat doesn't pull enough of the bad stuff out of the exhaust.My understanding is that E85 doesn't produce the chemicals that a cat needs to filter out, so that's a possibility.Yep, did read your thread. Similar issues, but not as ... severe... As far as I know, as long as a cat converter is "warmed up" it'll have no problem catalysing the exhaust even if it is higher flow than a stock one (to a point, of course). A "stoich" tune will give off very little chemicals requiring conversion (is the theory).He posted them!!!!Keith, do a skid ya mad cnt godammitI think I preferred not knowing anything. Big power car sitting in limbo sux balls.Phil, I'm not sure how my car would go in an official test since it's never had one, but Simon at XFt used my car as a guinea pig to test his new gas analyser addon to his Mainline dyno a few years back. I have a twin cat Manta 2x2.5" system and he passed the test simulation with it, so he told me. Have to hold revs at certain points to match some sort of pre existing path, I'm fuzzy on the details though. Gives hope however. Problem is you'd want to know for sure before stumping up $1600, fark.Yeah, a 5 gas analyser on a dyno should give a reasonable indication of whether it'll pass that's essentially the plan.SEEeeeeeeeeee KeithThis thread is good - not only for you but for the stripe boi as well as he delivered pics Agreed The thread can definitely stay, now, even if I make a better one hahaha 2 Link to comment Share on other sites More sharing options...
Wilko16 Donating Members 1,672 Member For: 16y 5m 4d Gender: Male Location: Melbourne Posted 22/11/15 11:29 PM Share Posted 22/11/15 11:29 PM Put it on BBQ fuel like Rab... Pass emissions straight away 1 Link to comment Share on other sites More sharing options...
Rab WOT? Moderating Team 10,980 Member For: 11y 2m Gender: Male Location: Frankston, 3199 Posted 23/11/15 12:20 AM Author Share Posted 23/11/15 12:20 AM Wouldn't be cheap - maybe not even viable with the gear he hasI reckon Keiths plan to do it correctly and do it once is the right way 1 Link to comment Share on other sites More sharing options...
Tocchi Sandtrap Motorsport Donating Members 2,055 Member For: 15y 5m Gender: Male Location: Perth Posted 23/11/15 01:45 AM Share Posted 23/11/15 01:45 AM Ok I'll start because we know this works A: you crashed your last car with no insurance B: you had your last car stolen with no insurance C: your last car broke and you got raped on repairsOr any combo of A/B/COr Tocchi: catastrophic engine failure putting you into a wall at over 100kmhHaha 1 Link to comment Share on other sites More sharing options...
_Velocity_ Bronze Donating Members 2,768 Member For: 13y Gender: Male Location: Victoria Posted 23/11/15 05:27 AM Share Posted 23/11/15 05:27 AM Just ring up Volkswagen. They are skilled at cheating the EPA! 1 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,303 Member For: 16y 15d Gender: Male Location: Melbourne Posted 23/11/15 05:32 AM Share Posted 23/11/15 05:32 AM yeahhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh Link to comment Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,751 Member For: 12y 9m 4d Posted 23/11/15 07:09 AM Share Posted 23/11/15 07:09 AM I'll give you 8K for it Keith. Save you all the hassle of working on it 1 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,303 Member For: 16y 15d Gender: Male Location: Melbourne Posted 23/11/15 07:10 AM Share Posted 23/11/15 07:10 AM nnnaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaahhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh Link to comment Share on other sites More sharing options...
barnz Member 3,047 Member For: 10y 5m 5d Gender: Male Location: Brisbane Posted 23/11/15 07:17 AM Share Posted 23/11/15 07:17 AM Swap you a G6ET? Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,303 Member For: 16y 15d Gender: Male Location: Melbourne Posted 23/11/15 07:17 AM Share Posted 23/11/15 07:17 AM definitely not Link to comment Share on other sites More sharing options...
