Bigg_kayz Member 111 Member For: 9y 7m 3d Gender: Male Location: Perth, Northsider Posted 29/08/15 10:56 AM Share Posted 29/08/15 10:56 AM BA mkii xr6t ute 500rwhp - heavy duty twin plate clutchAfter my recent retune ive noticed that when I push in my clutch the revs dont drop to idle point... the only time I reach idle revs is at a stand still.say if im cruising at 80km/h and put into neutral or keep the clutch depressed the revs will drop with the speed ,, why would this be? Its even worse on cold start and im finding when cold the revs jump around a fair bit , some times ill even get a stall if I try take off after first cold start in the mornings, never had this issue with other xr6ts or tunes?? Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 18y 6m 27d Gender: Male Location: Perth Posted 29/08/15 11:30 AM Share Posted 29/08/15 11:30 AM Some tuners do this to make manual cars easier to shift at high rpm. Link to comment Share on other sites More sharing options...
Bigg_kayz Member 111 Member For: 9y 7m 3d Gender: Male Location: Perth, Northsider Posted 29/08/15 11:39 AM Author Share Posted 29/08/15 11:39 AM ahh I see, what exactly do they edit to allow the car to register the revs in accordance with speed rather than clutching ? Link to comment Share on other sites More sharing options...
chris_richo Member 8 Member For: 13y 7m 14d Gender: Male Location: port macquarie Posted 05/09/15 04:07 AM Share Posted 05/09/15 04:07 AM I had a similar problem, would idle at around 1600 rpm then drop to normal when car fully stopped. Also had a rough idle on cold starts. Turned out to be a leaking intake manifold gasket. I Replaced it then found a new tuner as mine left the shop like that! Thanks to c&v... Link to comment Share on other sites More sharing options...
Bigg_kayz Member 111 Member For: 9y 7m 3d Gender: Male Location: Perth, Northsider Posted 13/09/15 11:01 PM Author Share Posted 13/09/15 11:01 PM (edited) so I should be taking off the intake plenum and checking that out possibly? seems to be a similar issue with mine Edited 13/09/15 11:03 PM by Bigg_kayz Link to comment Share on other sites More sharing options...
barnz Member 3,047 Member For: 10y 4m 30d Gender: Male Location: Brisbane Posted 13/09/15 11:19 PM Share Posted 13/09/15 11:19 PM Was it the upper to lower gasket or the manifold to head gasket chris? Link to comment Share on other sites More sharing options...
chris_richo Member 8 Member For: 13y 7m 14d Gender: Male Location: port macquarie Posted 14/09/15 11:14 AM Share Posted 14/09/15 11:14 AM Sorry for the late reply. Mine leaked where the intake manifold bolts to the motor coz the gasket was stuffed. U can check for leaks by VERY CAREFULLY spraying some throttle body cleaner or wd40 around the manifold, if there's a leak there will be a slight drop in revs. I'm no mechanic so there might be a safer way of checking for leaks. Maybe the manifold bolts need to be re tourqed. Good luck keep us posted Link to comment Share on other sites More sharing options...
Bigg_kayz Member 111 Member For: 9y 7m 3d Gender: Male Location: Perth, Northsider Posted 27/10/15 11:29 PM Author Share Posted 27/10/15 11:29 PM sorry for the late response, but it looks like chris is right, had it in yesterday at the mechanics and it was mentioned that theres in intake manifold leak... will be re-booking to get it rectified in a couple of weeks. sometimes if I start my car on cold start itll start run for 10-15 seconds then die till I kick it over again. It seems to be the same gasket as you described as the nizpro plenum side of things is sealed. Link to comment Share on other sites More sharing options...
