Bad Apples Donating Members 110 Member For: 18y 8m 28d Gender: Male Posted 13/08/12 06:57 AM Share Posted 13/08/12 06:57 AM xcal3 can't log the ford specific PIDs aka direct memory requests for the BA and you have to use an xcal2.Thanks Toad, this is good to know. Does that enable spark source logging for BA's? (or what exactly does it allow over xcal3/HPT)?Anyway, Anyone wanna swap their Xcal 2 for my Xcal 3?Cheers,Chris. 1 Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 18y 6m 27d Gender: Male Location: Perth Posted 13/08/12 07:00 AM Author Share Posted 13/08/12 07:00 AM ^ spark source/torque source, fuel source etc etc etc. All the good stuff you wan to know. Have a look at all the Parameters in live link that are in CAPITALS they are all DMR's that an X2 can log on a BA.Edit: ^ I learnt that at the Church of Toad. Link to comment Share on other sites More sharing options...
turbotrana Member 2,586 Member For: 21y 20d Gender: Male Posted 13/08/12 07:14 AM Share Posted 13/08/12 07:14 AM This is a pretty good thread to understand the fueling side of adjustments Link to comment Share on other sites More sharing options...
Sasha Member 141 Member For: 16y 8m 11d Gender: Male Location: North Queensland Posted 13/08/12 08:23 AM Share Posted 13/08/12 08:23 AM Hey mate, I think they may still give you support since at the end of the day it is their product. The ebay seller may be an authorised re-seller or distributor. If so its all good.No good Paulie...When I had issues with my interface not working they asked for the number on the interface ans as it didn't match the list of ones they have sold they turned me away. LUCKILY, Bill @ HP Tuners come to the party and they sent me a new interface out of Aus. Otherwise, support? What support lolIf you want support, buy from VCM Aus. Simple. They were quite open in telling me that also 2 Link to comment Share on other sites More sharing options...
Sasha Member 141 Member For: 16y 8m 11d Gender: Male Location: North Queensland Posted 13/08/12 08:34 AM Share Posted 13/08/12 08:34 AM Anyone starting out may benefit from these Source Values when datalogging with their Xcal. VERY handy if you are experiencing torque reduction or encounter an unknown condition and you want to know where to start looking. Enjoy Spark Source Values:0 Crank or under speed1 Base2 Borderline3 Torque control4 Pre-ignition6 Stabilized low load7 Cold engine low load8 Idle feedback at minimum clip9 Idle feedback10 Spark set by on-demand self-test15 Output State Control16 Foreground Spark Borderline Clip18 Closed-Throttle Deceleration SparkFuel Source0 Closed Loop fuel control mode is active.1 Cylinder cutout - Stabilized - Short Term Fuel Trim at lean stability limit.2 Some Exhaust Component too hot - Enrich Short Term Fuel Trim to cool exhaust temperatures.3 Cylinder cutout - Stabilized - Short Term Fuel Trim controlled by torque control feature.4 Cold engine/startup open loop logic – Cold start up engine table5 Stabilized normal drivability logic - Base fuel Table6 Lean fuel error logic.7 Engine running EGO monitoring testing - intrusive Short Term Fuel Trim control.8 Engine running On-Demand testing - Short Term Fuel Trim controlled by OBD-II exec.9 Cylinder cutout - Cold Engine - Short Term Fuel Trim controlled rich to avoid stumbles.10 Snap Adaptive - ramping Short Term Fuel Trim towards stoich for KAM update.12 Thermactor Air test - intrusive Short Term Fuel Trim control.13 Open Loop Development override - Short Term Fuel Trim set to calibrated scalar.TQ_SOURCE Identifies the source of the torque reduction requestor0 No Torque Reduction Requested (Torque Control Off)1 Torque truncation, transmission2 Traction Control3 Vehicle Speed Limiter4 Engine Speed Limiter5 Tip-in shock Control6 Tip-out Decel Control7 Torque Shift Modulation, transmission8 Engine Oil Temperature Control9 Fail Safe Cooling Control11 Turbo Charger12 Passive Anti Theft system (PATS)13 Tip in Torque ControlTQ_SOURCE Source of torque reduction:0 Driver Demand1 Transmission torque truncation2 Traction Control3 Vehicle Speed Limiting4 Engine Speed Limiting5 Tipin rate limiting6 Tipout torque7 Transmission Shift Modulation8 Engine Oil Over temperature9 Target N Link to comment Share on other sites More sharing options...
45T-XR Donating Members 417 Member For: 17y 1m 13d Gender: Male Location: Gladstone, Queensland Posted 13/08/12 09:02 AM Share Posted 13/08/12 09:02 AM I remember seeing those in livelink, havent seen if they work with the xcal3 on the bf. anyone know Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 18y 6m 27d Gender: Male Location: Perth Posted 13/08/12 09:02 AM Author Share Posted 13/08/12 09:02 AM If you want support, buy from VCM Aus. Simple. They were quite open in telling me that also For tuning based support (which is minimal) yes, for software support I deal directly with Bill from HPT in the US.Did you take the time to type out all the source values? If you did good on you. If you have a document that C&P'd them from Dibs on a copy! 1 Link to comment Share on other sites More sharing options...
IH8TOADS Silver Donating Members 3,618 Member For: 18y 9m 11d Gender: Male Location: OZ Posted 13/08/12 10:49 AM Share Posted 13/08/12 10:49 AM I remember seeing those in livelink, havent seen if they work with the xcal3 on the bf. anyone knowYes. Been issues over the yrs though with some torque source data, mostly related to the version of livelink being used. Link to comment Share on other sites More sharing options...
useless Member 259 Member For: 19y 10m 17d Gender: Male Posted 13/08/12 12:33 PM Share Posted 13/08/12 12:33 PM I just ordered VCM pro from this ebay site, being delivered from US for $US700.http://cgi.ebay.com....em=200588303550And yes he said it supports our Aussie Ford Turbos.It might be a mistake as I am sure the Australian VCM does provide some support whereas I dont see this ebay guy giving any support.Nevertheless its Sunday afternoon and a purchase on ebay or online is just a few clicks away, I just couldn't be bothered waiting till Monday to ring up the Aust VCM suite, just too hard. It does not support fg automatic transmission Link to comment Share on other sites More sharing options...
turbotrana Member 2,586 Member For: 21y 20d Gender: Male Posted 13/08/12 12:39 PM Share Posted 13/08/12 12:39 PM HP Tuners has not done the 6 speed auto yet. From what I have gathered the US HP Tuner, whether you buy it from US, ebay or Aust is all the same product. Link to comment Share on other sites More sharing options...
