jaydanfgturbo New Member 15 Member For: 8y 8m 24d Posted 06/08/15 04:56 AM Share Posted 06/08/15 04:56 AM Hi all, reasonably new to this group but having dramas with my fg. Car is an fg with a built 698 atomic engine with about 50000km on it. It started off dropping number 5 cylinder with a fault code suggesting it was coils, changed coils same problem. Got a new computer and loaded myHi all, reasonably new to this group but having dramas with my fg. Car is an fg with a built 698 atomic engine with about 50000km on it. It started off dropping number 5 cylinder with a fault code suggesting it was coils, changed coils same problem. Got a new computer and loaded my files onto it and it was fixed... For about half an hour then dropped 5 again. After that You could start it up and it would run on sequential injection for the first 10 seconds then immediately drop number 5 again. So we decided maybe we would do the imjector harness. So we replaced that and got another new computer and loaded files onto it. At last she ran on all 6, even dynoed it and all again. Then without warning its dropped number 1 cylinder, with fault codes pointing to coil windings, swapped coils but number one has nothing. Doesn't even run on 6 when first started. That brings us to today. Starts and runs on 5 cylinders. I'm at breaking point and any help would be appreciated files onto it and it was fixed... For about half an hour then dropped 5 again. After that You could start it up and it would run on sequential injection for the first 10 seconds then immediately drop number 5 again. So we decided maybe we would do the imjector harness. So we replaced that and got another new computer and loaded files onto it. At last she ran on all 6, even dynoed it and all again. Then without warning its dropped number 1 cylinder, with fault codes pointing to coil windings, swapped coils but number one has nothing. Doesn't even run on 6 when first started. That brings us to today. Starts and runs on 5 cylinders. I'm at breaking point and any help would be appreciated Cheers Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 10m 23d Gender: Male Location: Adelaide Posted 06/08/15 09:05 AM Share Posted 06/08/15 09:05 AM 4 Link to comment Share on other sites More sharing options...
Bizkets is Drunk? Too heavy needs boost Member 5,929 Member For: 10y 8m 17d Gender: Male Location: Adelaide Posted 06/08/15 09:26 AM Share Posted 06/08/15 09:26 AM Ground hog day for sure. Lol 2 Link to comment Share on other sites More sharing options...
jaydanfgturbo New Member 15 Member For: 8y 8m 24d Posted 06/08/15 09:27 AM Author Share Posted 06/08/15 09:27 AM Do not know what the f*ck happened there but I too am confused -_-Sent from my SM-G900I using Tapatalk 1 Link to comment Share on other sites More sharing options...
jaydanfgturbo New Member 15 Member For: 8y 8m 24d Posted 06/08/15 09:35 AM Author Share Posted 06/08/15 09:35 AM Hi all, reasonably new to this group but having dramas with my fg. Car is an fg with a built 698 atomic engine with about 50000km on it. It started off dropping no. 5 cylinder with a fault code suggesting it was coils, changed coils same problem. Got a new computer and loaded my files onto it and it was fixed... For about half an hour then dropped no. 5 again. After that You could start it up and it would run on sequential injection for the first 10 seconds then immediately drop number 5 again. So we decided maybe we would do the injector harness. So we replaced that and got another new computer and loaded files onto it. At last she ran on all 6, even ran it up on the dyno and all again. Then without warning its dropped number 1 cylinder with fault codes pointing to coil windings, swapped coils but number one still has nothing. Doesn't even run on 6 when first started immediately runs on 5 cylinders That brings us to today. Starts and runs on 5 cylinders. I'm at breaking point and any help would be appreciated. CheersSent from my SM-G900I using Tapatalk Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 10m 23d Gender: Male Location: Adelaide Posted 06/08/15 09:53 AM Share Posted 06/08/15 09:53 AM 1 Link to comment Share on other sites More sharing options...
jaydanfgturbo New Member 15 Member For: 8y 8m 24d Posted 06/08/15 09:54 AM Author Share Posted 06/08/15 09:54 AM Yea you used that one earlierSent from my SM-G900I using Tapatalk Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 10m 23d Gender: Male Location: Adelaide Posted 06/08/15 10:21 AM Share Posted 06/08/15 10:21 AM 2 Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 18y 7m Gender: Male Location: Perth Posted 06/08/15 10:27 AM Share Posted 06/08/15 10:27 AM 1 Link to comment Share on other sites More sharing options...
jaydanfgturbo New Member 15 Member For: 8y 8m 24d Posted 06/08/15 10:29 AM Author Share Posted 06/08/15 10:29 AM No one able to help?Sent from my SM-G900I using Tapatalk Link to comment Share on other sites More sharing options...
