Bomber Carnage on the Garage Floor Donating Members 3,994 Member For: 13y 11m 8d Gender: Male Location: Gold Coast Posted 20/05/15 11:14 AM Share Posted 20/05/15 11:14 AM My stock balancer was still ok but...my tuner really dislikes them when making a bit of power. Mine does feel a little bit more responsive with the powerbond unit fitted too. Good work taking it on yourself.Quick tip for those trying to crack the bolt. I don't know which relay it was but Bionic the clever bugger used the starter to crack it with a long extension against the passenger side rail as he'd done another balancer in the morning and broke his power bar in the process - doh! I held the socket and extension in place the he jumped the starter from the fuse box a couple of times and it undid it for us - win! No starter out or lock the crank required. Sorry I didn't get this info to you beforehand as it would've saved you some punish. 1 Link to comment Share on other sites More sharing options...
OZYWALKER XR50T Gold Donating Members 2,795 Member For: 10y 11m 18d Gender: Male Location: Western Sydney Posted 20/05/15 11:35 AM Author Share Posted 20/05/15 11:35 AM All good mate, I had thought about that but wasn't keen on tightening the bolt the same way. By pulling out the starter I was able to tighten the bolt no probs. Link to comment Share on other sites More sharing options...
OZYWALKER XR50T Gold Donating Members 2,795 Member For: 10y 11m 18d Gender: Male Location: Western Sydney Posted 15/06/15 08:56 AM Author Share Posted 15/06/15 08:56 AM Ordered a coil over and adjustable rear damper kit from Shockworks last week. It arrived today, top looking bit of kit and as a lot of others have said Brett is a top bloke to deal with.Going to fit them this weekend to see how well it all goes with the stock bushes as they'll be getting changed soon enough. 1 Link to comment Share on other sites More sharing options...
OZYWALKER XR50T Gold Donating Members 2,795 Member For: 10y 11m 18d Gender: Male Location: Western Sydney Posted 21/06/15 05:11 AM Author Share Posted 21/06/15 05:11 AM Shockworks all in and fitted a set of Calvert Racing Caltracs Shockworks are pretty easy to install, undo a few nuts and bolts swear a bit then put the nuts/bolts back.The Caltracs come with a solid aluminium bush for the front eye in the leaf springs. Left in the freezer overnight and it pressed in fairly easily. Hardest part was getting the stock eye bush out. Hole saw + Map gas FTW.The rest was pretty simple. Bolt it all up, get the wheels on, and set the preload when it was on the floor.Since I've moved the header tank and ECU adjusting the front dampers is a breeze.Only issue is the front hangar does hang fairly low, might move it to the top hole if it causes problems. And its RSpec now.......... 2 Link to comment Share on other sites More sharing options...
Grego.77 Member 195 Member For: 9y 5m Gender: Male Location: St Clair NSW Posted 03/07/15 12:24 PM Share Posted 03/07/15 12:24 PM Awesome build. Like the ecu removed. 1 Link to comment Share on other sites More sharing options...
OZYWALKER XR50T Gold Donating Members 2,795 Member For: 10y 11m 18d Gender: Male Location: Western Sydney Posted 29/07/15 10:53 AM Author Share Posted 29/07/15 10:53 AM Got a bit done over the last few weeks. Fitted the technico billet tail shaft coupling a while back and its held up so far, the washers they now supply with it seem to do the job.The only noticable change in NVH is you can hear when the gearbox loads/unloads any driveline slack when under 10-20km.Leveled out the ride height a bit. Raised the front coil overs and lowered the rear a bit by removing the helper leaf springs. Also cut the front caltrac bracket to give some more clearance.Then added some more black to the bay. 1 Link to comment Share on other sites More sharing options...
OZYWALKER XR50T Gold Donating Members 2,795 Member For: 10y 11m 18d Gender: Male Location: Western Sydney Posted 19/09/15 12:05 PM Author Share Posted 19/09/15 12:05 PM Got my hands on a Jonny Tig cooler kit about a month ago. Its a top bit of kit, quality tube and fin cooler with a 3" hot and cold side.Does the job really well and weighs a lot less than the PW stage 3.Side by sideWon't put up a comparison between the two as ambient temp was pretty different on test days. But its not a step back by any means. 5 Link to comment Share on other sites More sharing options...
julesk_1972 Member 267 Member For: 11y 8m 25d Gender: Male Location: Perth Posted 19/09/15 09:44 PM Share Posted 19/09/15 09:44 PM What power are you aiming for? Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 10m 19d Gender: Male Location: Adelaide Posted 20/09/15 01:14 AM Share Posted 20/09/15 01:14 AM In your opinion how much less does the jonny tig cooler weigh vs the PW3 ? Link to comment Share on other sites More sharing options...
Bizkets is Drunk? Too heavy needs boost Member 5,929 Member For: 10y 8m 13d Gender: Male Location: Adelaide Posted 20/09/15 01:51 AM Share Posted 20/09/15 01:51 AM The big one felt 50% lighter then my old pw stepped Link to comment Share on other sites More sharing options...
