pj4000 New Member 23 Member For: 9y 4m Gender: Male Location: Central Coast NSW Posted 22/11/16 06:22 AM Share Posted 22/11/16 06:22 AM Have you got a big exhaust and dump pipe? Link to comment Share on other sites More sharing options...
048oss New Member 12 Member For: 8y 9m 20d Posted 22/11/16 10:20 AM Share Posted 22/11/16 10:20 AM 4inch exhaust. Got a garret rear housing with extra large waste gate hole/flapper 1 Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 10m 18d Gender: Male Location: Adelaide Posted 22/11/16 11:38 AM Share Posted 22/11/16 11:38 AM You have to much pre load tell Dale to help out more with answers hahahahahaha 1 Link to comment Share on other sites More sharing options...
048oss New Member 12 Member For: 8y 9m 20d Posted 23/11/16 10:51 AM Share Posted 23/11/16 10:51 AM (edited) Have talked to a bloke up here with the same actuator and he has it working well with 1.8mm preload. going to leave mine like it is at the moment and leave it on the spring till next year. Shes making 366rwkw on 15ish psi on a 35c+ day so that will do over xmas, a little less preload and 20psi next year Edited 23/11/16 10:53 AM by 048oss Link to comment Share on other sites More sharing options...
Dat111 Member 30 Member For: 1y 11m 8d Posted 22/09/22 10:36 PM Share Posted 22/09/22 10:36 PM hey guys, how much preload is suggested? 1.5mm to much, 2mm is to much.. 1mm? ill be using a pulsar rear housing with a TS gate an porting the rear housing using a die grinder. Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,115 Member For: 9y 2m 20d Gender: Male Location: South Australia Posted 22/09/22 10:51 PM Share Posted 22/09/22 10:51 PM There isn't a one size fits all approach to this but if you wanna set it and forget it make it very light. If you wanna run your boost level at the max the spring will make, you want more preload. If you're running your boost level closer to the spring pressure you want less preload. If you have a free flowing exhaust you want less preload. With a factory exhaust you can have more preload. With a larger wastegate you can have more preload, with a smaller hole you'll want less. With a manual car you will usually want more preload, with an auto usually less. With a larger turbine wheel you can run more preload, with a larger compressor side you might want less. Ported housing can have more, non ported might still be sh*t even with the lightest possible preload. None of this is mutually exclusive, there are exceptions to all of these, some of them mixed will be the opposite, there will be many more scenarios to consider and there is more than one way to skin a cat. Tl;Dr Set it so the flap is only just closed and then wind the rod about 1/4 to 1/2 a turn more. 3 Link to comment Share on other sites More sharing options...
hjtrbo Bronze Donating Members 309 Member For: 13y 2m 30d Posted 23/09/22 11:49 PM Share Posted 23/09/22 11:49 PM Maybe a better way to put that question, If targeting x boost with y spring, assuming everything else being equal and correct, what are the symptoms of too little preload and too much preload. Scenarios: x =1 * y (I.e. boost 12 psi, spring 12psi) x = 2 * y (I.e. boost 24 psi, spring 12psi) x = 1.5 * y (I.e. boost 18 psi, spring 12psi) Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,115 Member For: 9y 2m 20d Gender: Male Location: South Australia Posted 24/09/22 12:06 AM Share Posted 24/09/22 12:06 AM May as well click this link instead Link to comment Share on other sites More sharing options...
hjtrbo Bronze Donating Members 309 Member For: 13y 2m 30d Posted 24/09/22 07:13 AM Share Posted 24/09/22 07:13 AM Fark that, better when dad chicken does it Actually,,,, that's a pretty good article. 🤥 Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,115 Member For: 9y 2m 20d Gender: Male Location: South Australia Posted 24/09/22 08:23 AM Share Posted 24/09/22 08:23 AM I ain't doin nuffin 1 Link to comment Share on other sites More sharing options...
