pj4000 New Member 23 Member For: 9y 4m 7d Gender: Male Location: Central Coast NSW Posted 19/07/16 11:53 AM Share Posted 19/07/16 11:53 AM Hi Guys, I need of a bit of help here.First up, car is tune for this actuator.Actuator is a Turbo Smart IWG75 with a 12 pound spring.Was running at 15 psi of boost for a few months, then it's started boost cutting at 20+ psi. In an attempt to find out what is wrong, I tried bypassing the stock electronic boost controller and expected to see roughly 12psi of boost but I didn't, it kept boosting till the gauge hit 20psi and then the ecu cut in and went into a limp mode.Skipping forward. Today I took the turbo out to see what if the waste gate actuator is at fault.Turns out I can't move it by hand, not sure if this is normal or not? When I connect a hand pump to it, it moves.Following this I connected it to a bike pump and set the pressure to 5psi, actuator moved.Tried again at 12psi moved further but wasn't fully extended.Kept upping the pressure up by 2psi until it reached the max extent, turned out to max out at 22psi. Is this normal? Shouldn't it be fully extended by 12psi?ThanksA search led me here, good old grave dig.I've tested my 7psi spring as you did with your 12psi Spring.I have 1.5 turns of preload which is about the 2mm.When I pump air into the actuator the rod doesn't start moving till 7psi then isn't fully extended till 14psi. Is the rated spring meant to be the end psi result or is it meant to be the beginning of when the flap starts to open ?Trying to fix my overboosting issue on BA. Hence landing here via search. Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 10m 25d Gender: Male Location: Adelaide Posted 19/07/16 12:08 PM Share Posted 19/07/16 12:08 PM Spring rated pressure is "cracking" pressure only, not full extend pressure the Turbosmart IWG is a tricky beast on the XR turbo and ALOT of tuners dislike them as they can be a bitch I had good success using and tuning them but I had to tweak my installation methods to get desired outcomes on customer cars Link to comment Share on other sites More sharing options...
pj4000 New Member 23 Member For: 9y 4m 7d Gender: Male Location: Central Coast NSW Posted 19/07/16 12:23 PM Share Posted 19/07/16 12:23 PM Hey thanks for clearing up the "cracking" pressure.If the 7psi Spring had the flap fully opened at 14psi would it mean if I fitted the 5psi Spring the flap would be full open at 10psi ? I'm trying to get this boost down to a stable level. Car came with 4-5" dump pipe into what looks like a very well made 3.5" exhaust. Standard port wastegate still. Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 10m 25d Gender: Male Location: Adelaide Posted 19/07/16 12:48 PM Share Posted 19/07/16 12:48 PM (edited) Well that's your issue mate, port size is to small you need the 38mm port and flap job done and while you're at it fit a genuine 8psi Garrett actuator !! Edited 19/07/16 12:48 PM by JETURBO 1 Link to comment Share on other sites More sharing options...
pj4000 New Member 23 Member For: 9y 4m 7d Gender: Male Location: Central Coast NSW Posted 19/07/16 01:12 PM Share Posted 19/07/16 01:12 PM Looks like I best be doing the port job. Have been reading lots of posts on here about that.Being I already have the iwg75 , wouldn't the 5psi Spring be ok to use with the ported housing? Just thinking of way not to have to buy another actuator. Link to comment Share on other sites More sharing options...
Guest Guests Posted 19/07/16 01:33 PM Share Posted 19/07/16 01:33 PM Rull of thumb on internal wastegates is to not go higher than double the spring pressure. So 5psi - max should be 10 10 - max would be 20psi And so on.... Ofcourse that doesnt mean you cant and nearly everyone does but that's what garrett etc recommend. Are you sure you dont have the preload too tight? Link to comment Share on other sites More sharing options...
pj4000 New Member 23 Member For: 9y 4m 7d Gender: Male Location: Central Coast NSW Posted 19/07/16 01:48 PM Share Posted 19/07/16 01:48 PM I'm confident I have the preload correct. Made rod just neatly slip over the lever of the flap, then pulled the rod off and shortened rod by 1.5 turns. Flap cracks open at exactly 7psi too. I'm not looking for big power. Just be happy with low boost that won't skyrocket when full throttle is given. Looks like the port job as mentioned above is a must do thing to give me any hope of getting boost down. Am thinking with the port job and fit the 5psi Spring I should have low stable boost. 1 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,303 Member For: 16y 15d Gender: Male Location: Melbourne Posted 19/07/16 01:51 PM Share Posted 19/07/16 01:51 PM If you can get the actuator set so that you don't run high boost, you don't need a port/flap job. Port/flap job is done to control boost better... but low boost (read: stock level plus only a small amount) can easily be controlled in comparison to the higher boost capability of the stock turbo. Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 18y 7m 2d Gender: Male Location: Perth Posted 19/07/16 09:58 PM Share Posted 19/07/16 09:58 PM Lolwut Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 10m 25d Gender: Male Location: Adelaide Posted 20/07/16 12:03 AM Share Posted 20/07/16 12:03 AM Keif WTF bro Link to comment Share on other sites More sharing options...
