JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 10m 18d Gender: Male Location: Adelaide Posted 16/01/15 11:39 AM Share Posted 16/01/15 11:39 AM Yeh I understand iam just pointing at water, u dont have to drink it 2 Link to comment Share on other sites More sharing options...
Serangan Member 103 Member For: 10y 6m 27d Gender: Male Location: Hobart, Tasmania Posted 16/01/15 11:41 AM Author Share Posted 16/01/15 11:41 AM No harm. Didn't mean for that to come across is a nasty way Link to comment Share on other sites More sharing options...
Serangan Member 103 Member For: 10y 6m 27d Gender: Male Location: Hobart, Tasmania Posted 17/01/15 03:56 AM Author Share Posted 17/01/15 03:56 AM So adjusted the preload and turbo back on today.Took into account what you said jet and its currently sitting a roughly 1.5mm preload. Took it for a spin and its holding the boost at 17psi using the boost controller. Didn't hook it straight up. That can be tomorrows jobBut most importantly it isn't cutting like it was before and isn't spiking! so seems to be better 1 Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 10m 18d Gender: Male Location: Adelaide Posted 17/01/15 05:20 AM Share Posted 17/01/15 05:20 AM Water tastes good ? Lol no worries iam actually here to help And call people soft c0cks 2 Link to comment Share on other sites More sharing options...
Serangan Member 103 Member For: 10y 6m 27d Gender: Male Location: Hobart, Tasmania Posted 17/01/15 06:52 AM Author Share Posted 17/01/15 06:52 AM Sure does.I've seen your method of advice on hp tuners forum and must say I do like it.Hopefully touch up tune on Tuesday will ensure everything is set right and is a happy engine 1 Link to comment Share on other sites More sharing options...
Serangan Member 103 Member For: 10y 6m 27d Gender: Male Location: Hobart, Tasmania Posted 18/01/15 01:04 AM Author Share Posted 18/01/15 01:04 AM Disconnected the electronic boost controller and took it for a spin. Still hitting 17psi, exactly the same as with the controller hooked up. What is wrong with this car. It used to work and hold 15psi then it just stopped doing it. Link to comment Share on other sites More sharing options...
bamk2f6tornado Bronze Donating Members 777 Member For: 10y 4m 15d Gender: Male Location: Rockhampton Qld Posted 18/01/15 03:04 AM Share Posted 18/01/15 03:04 AM Mine has an eboost but it and the standard boost control are disabled. Mine steadies at about 17 then creeps up to 19lbs. Link to comment Share on other sites More sharing options...
Serangan Member 103 Member For: 10y 6m 27d Gender: Male Location: Hobart, Tasmania Posted 21/01/15 11:16 AM Author Share Posted 21/01/15 11:16 AM Stock boost actuator back in. No more over boosting and holds 6psi.Still does a weird cut on full acceleration but at least the boost is under control now.And fyi stock boost levels are boring now 1 Link to comment Share on other sites More sharing options...
useless Member 259 Member For: 19y 10m 16d Gender: Male Posted 19/04/15 11:10 AM Share Posted 19/04/15 11:10 AM Sounds like yours may have been faulty Serangan Link to comment Share on other sites More sharing options...
Serangan Member 103 Member For: 10y 6m 27d Gender: Male Location: Hobart, Tasmania Posted 19/04/15 01:19 PM Author Share Posted 19/04/15 01:19 PM Not sure in the end. Held pressure fine. It did work to start with then nothing.Local tuner I bough it from wasn't being too helpful so I moved on and haven't thought about it since Link to comment Share on other sites More sharing options...
