judgee New Member 23 Member For: 13y 5m 9d Posted 26/12/14 11:00 AM Share Posted 26/12/14 11:00 AM I have recently bought a Mal Wood CSC for my BA XR6T. I live very remote and have been in talks with the local mechanic about changing it. He has never done one before and seems tentative and worried about doing the procedure, he said he has read up on it and asked a mate who has done it before and is quoting me around 5-8 hrs to remove the box. My question is from my understanding you disconnect the box from bell housing, remove or slide back box, remove CSC, reinstall new CSC, bolt box back up. Is it that simple or is there a lot more involved. He is telling me that I should be replacing my clutch while the box is out. I said well I think the previous owner has replaced with some form of heavy duty one as the clutch is very heavy and bites hard. Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 9m 26d Gender: Male Location: Adelaide Posted 26/12/14 11:52 AM Share Posted 26/12/14 11:52 AM Travel to a place that knows what they are doing mate because if he fluffs it up your in expensive land all by your self Link to comment Share on other sites More sharing options...
judgee New Member 23 Member For: 13y 5m 9d Posted 26/12/14 12:14 PM Author Share Posted 26/12/14 12:14 PM I wish I could but the car is undriveable as it is so I don't have a choice. Link to comment Share on other sites More sharing options...
clevo400 Member 32 Member For: 13y 2m 5d Gender: Male Location: Townsville Posted 05/01/15 11:36 AM Share Posted 05/01/15 11:36 AM I'm in the same boat and "Yes" my mechanic is going to check the old csc hasn't leaked onto the clutch. If so then I will replace the clutch but it feels fine atm like yours. If the clutch slips later on then it's another $400 labour pulling it out again so I'll live with it and I'll put a CI twin plate clutch in. Did you get the alloy piston csc with earls line or the std plastic csc from Mal. I've also heard (actually been told) I can use the alloy csc from the err... VT-VZ. $100 Cheaper. Damn Holdens lol. Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 18y 6m 5d Gender: Male Location: Perth Posted 05/01/15 11:50 AM Share Posted 05/01/15 11:50 AM I didn't think the Holden unit was the correct height. Mal does an ally bodied billet piston unit these days. Well worth the coin. Link to comment Share on other sites More sharing options...
Trent0 The Toxic Rocket Donating Members 574 Member For: 13y 11m 3d Gender: Male Location: Brisbane Posted 05/01/15 12:24 PM Share Posted 05/01/15 12:24 PM Fairly sure he buys them from the same place as commodores get them Link to comment Share on other sites More sharing options...
clevo400 Member 32 Member For: 13y 2m 5d Gender: Male Location: Townsville Posted 11/01/15 06:08 PM Share Posted 11/01/15 06:08 PM OK. If I use the GM unit do I use a spacer/shim to get the correct height ??? Cheers. Link to comment Share on other sites More sharing options...
"Captain Retard" Member 1,417 Member For: 9y 10m 26d Gender: Male Location: Shellharbour NSW Posted 11/01/15 08:12 PM Share Posted 11/01/15 08:12 PM I've just had to replace my clutch line which involved sliding the box back a few inches.Although I didn't have to remove it completely, it was a straight forward job and I did it with no hoist.From what I understand about this job it is critical to slide the box back in carefully so as not to damage the clutch centre as it is a bit fragile.Also from what I've read there is some sort of procedure for setting up the CSC which I'm not familiar with.The fact that he is worried about doing the job is a good sign as it means he'll most probably be careful and take his time.Like I said I've just done part of this job on my garage floor for the first time and I was a bit worried but had no issues.If he's got a hoist then he should get it done in under 5 hours and that's if he's taking his time .Also use Ralph's tip which involves using 4 long studs where the gearbox bolts to the bell housing. This helps take the weight of the front of the box and helps guide the box back in to position.Pics below of guide studsI just got some long bolts and cut the heads off them.Honestly if he's changed gearboxes before then he should be able too get the job done, good luck, cheers. Link to comment Share on other sites More sharing options...
