camo86T Silver Donating Members 1,810 Member For: 10y 1m 17d Gender: Male Location: SW Sydney Posted 23/10/19 03:03 AM Share Posted 23/10/19 03:03 AM 4 hours ago, k31th said: 546kW on 98 @ only 24psi Link to comment Share on other sites More sharing options...
HI PSI Member 1,563 Member For: 17y 10m 4d Gender: Male Location: Central Queensland Posted 23/10/19 09:14 AM Author Share Posted 23/10/19 09:14 AM I'll just leave this here.. We started tuning again this morning. However, I had to leave for work at 10 am. I left the car with my tuner and hit the road. I got a call at around 11.30 informing me that he had reverted back to the BA/BF cam tables, as he was having issues when performing power runs. The power curves were very rough/erratic on the top end and going back to the BA/BF tables smoohed the curve almost instantly. We also saw more power (Recovered) by increasing cylinder pressure. With this, I assume that the camshaft separation was the cause of this issue. He went on to say that the car was breaking down when pushed over 30 psi. We put this down to the spark plug gap being a little to wide, as I had left them at 0.8mm. I had done this thinking that the CDI voltage would allow me to run a much larger gap and thereby get a better burn. Learnt my lesson there.. Anyway, my tuner also works away form home and had to leave at mid day. So we've left it as it is until he returns in a weeks time.. I'll keep you all posted on further work/tuning. 6 Link to comment Share on other sites More sharing options...
HI PSI Member 1,563 Member For: 17y 10m 4d Gender: Male Location: Central Queensland Posted 17/12/19 07:34 AM Author Share Posted 17/12/19 07:34 AM Got home on Sunday and planned to do some work on the car. I have to sort a better way to get to the plugs as the current configuration, while looking pretty cool, is a major headache to check/change plugs. I'm investigating a few options and plan on running a Supra style lead cap, so that I can access the plugs without having to remove the rocker cover garnish. I'v utilising the existing plug tube configuration that I have in conjunction with these plug tube tops. Unfortunately the Nizpro garnish has around 10 mm of material thickness in the spark plug area that has to be removed. But I guess that having to repaint the garnish is a small price to pay for ease of servicing/access.Each individual lead will likely be run between each runner of the plenum to a bank of coils below. I'll post some pics when they are available. Supra leads... 3 Link to comment Share on other sites More sharing options...
HI PSI Member 1,563 Member For: 17y 10m 4d Gender: Male Location: Central Queensland Posted 13/01/20 09:33 AM Author Share Posted 13/01/20 09:33 AM (edited) I managed to get some time with my engine guy today. As previously posted somewhere above, I had plans to change the ignition coil location and lead setup to allow ease of access for plug reads/change etc. We put the Nizpro cover on the mill and removed over 10 mm of thickness from the cover. I then resized the previous plug lead holes to fit the new covers. I am considering mounting a coil rack on the chassis rail and running the leads through the runners on the plenum. I'll check it out when I'm home next and post pictures as it progresses. Edited 13/01/20 09:34 AM by HI PSI 3 Link to comment Share on other sites More sharing options...
Slowxr6t Member 512 Member For: 5y 3m 25d Location: New zealand Posted 14/01/20 05:14 AM Share Posted 14/01/20 05:14 AM @HI PSI legendary build youve been doing the last few years, you must be a very patient man, mind you I just remembered it took me 13 years to convert my twin turbo 300zx to big single To4z, and get 450rwkw and 11.2 quarter mile. Keep up the good work! Hey I think I missed it somewhere in your posts but what driveshaft did you go for? And those 1400hp axles are they an off the shelf item for these xr6t and how much $ are they? Thanks Link to comment Share on other sites More sharing options...
HI PSI Member 1,563 Member For: 17y 10m 4d Gender: Male Location: Central Queensland Posted 13/05/20 09:12 AM Author Share Posted 13/05/20 09:12 AM Apologies for the lateness of my reply. I have been busy with another project and I haven't checked the thread for some time. Normally people read the thread and don't reply. Lol The building of the car was actually quite quick, but I lost interest there for a while. And I have a tendency to get it finished and then change/upgrade the car. This combined with a group of quality professionals that are booked out for months at a time, has resulted in the car laying idle for extended periods. Past mistakes with builds have taught me to do a job right and do it once. And that a poor man pays twice, due to cutting corners and quality standards. Good work takes time.. My tail shaft was built by Mal wood. It was more expensive than most, but the quality is outstanding. As for the half shafts, I ordered them directly form "The Driveline Shop" in the States. I believe that Diff Technics are an Australian supplier for the 1400 hp items. Back when I purchased the (Years ago) the were around 3k for a pair. Given the current exchange rate, I'd hate to think what they may be worth now... But, give Diff Technics a call and request a quote.. Keep in mind that BA/BF shafts are different to FG. I just found these on Ebay ($3,690) Look like they've gone up in price... - https://www.ebay.com/itm/BA-BF-Falcon-Upgraded-CV-Axle-Shafts-1400HP-Rated/383408523781?hash=item5944edca05:g:jb0AAOSw~w5eN5U~ Cheers 1 Link to comment Share on other sites More sharing options...
HI PSI Member 1,563 Member For: 17y 10m 4d Gender: Male Location: Central Queensland Posted 04/07/20 09:58 AM Author Share Posted 04/07/20 09:58 AM I finally got sick of the car sitting there, doing nothing.. Primarily, this is my fault. As I really couldn't be bothered (and don't have time (new project)) to redesign and manufacture new coil bracket mounts. All in order to make plug reading and change out easier. In order to rectify the issue, I have purchased a R35 coil kit from Platinum Racing Products. It should arrive early next week. Given that I modified the Nizpro cover for the cdi coils, I will manufacture a Carbon fiber coil cover to replace the metal unit. I'll also be completing the header tank removal and the installation of the Hammond thermostat housing. This should neaten the bay even more. I'll post some pics when I can.. 3 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,239 Member For: 15y 11m 19d Gender: Male Location: Melbourne Posted 04/07/20 10:01 AM Share Posted 04/07/20 10:01 AM that's a winner. Link to comment Share on other sites More sharing options...
HI PSI Member 1,563 Member For: 17y 10m 4d Gender: Male Location: Central Queensland Posted 13/07/20 12:01 PM Author Share Posted 13/07/20 12:01 PM (edited) Dummied up, ready for wiring... It was supposed to happen today, but my wiring guy/tuner had issues with a car he was dynoing.. Next week it is... I found that the mating the spring in the boot and the coil was questionable, due to the spring seating lower in the silicon. The coil is long enough to reach the spring, but you can't ensure that it is correctly seated. I stretched the spring with some pointy nosed pliers until it was flush with top of the silicon, so that I could seat it into the coil before it engages the silicon. Also be aware that the silicon will separate from the coil when removing and the pill will fall into the spark plug valley under the coil bracket... The silicon is a snug fit into the bracket and takes some effort to remove.. Edited 13/07/20 12:02 PM by HI PSI 3 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,239 Member For: 15y 11m 19d Gender: Male Location: Melbourne Posted 13/07/20 12:09 PM Share Posted 13/07/20 12:09 PM good info, Steve Link to comment Share on other sites More sharing options...
