HI PSI Member 1,563 Member For: 17y 10m 4d Gender: Male Location: Central Queensland Posted 07/01/15 10:45 AM Author Share Posted 07/01/15 10:45 AM (edited) Sorry mate, I was at the shop today and I forgot to ask. I'll get the answers for you tomorrow. New bits in transit..... Aeroflow fuel filter - AF66-2043S -12 fittings Dimensions - 7" x 2-1/2". AEROFLOW AF59-2431 - 10 micron stinless mesh filter AEROFLOW AF66-2246 Dual Billet Filter Mount Remote Power Steering Reservoir - PROFLOW 750ml Oil Catch can with breather, drain tap and -12 fitting. Edited 10/04/18 03:26 AM by k31th pb pics fix Link to comment Share on other sites More sharing options...
Skids4kids in the mid....not the bum like some Member 609 Member For: 10y 11m 6d Gender: Male Posted 07/01/15 11:04 PM Share Posted 07/01/15 11:04 PM Will 750ml be enough capacity for this setup breather wise? Link to comment Share on other sites More sharing options...
HI PSI Member 1,563 Member For: 17y 10m 4d Gender: Male Location: Central Queensland Posted 09/01/15 12:06 AM Author Share Posted 09/01/15 12:06 AM The standard tank is not a pressurised unit and has a capacity is 600ml. So it should be fine. We fitted the sump up to the short engine the other day, and the girdle and studs hit were way too long. This resulted in a gap of 8mm from the sump flange to the block. We ended up having to remove the ball bearings from under the studs and a lot of material from the sump. So what was considered a basic task turned into a 3 hour modification. While there we welded in a plate on the rear side of the sumps main oil pan, This is to stop oil from running to the back of the sump when doing hard launches. The engine and box were removed yesterday in preparation for painting. CNC'ing if the valve seats should be competed today. So, final assembly should be completed in the coming days. 1 Link to comment Share on other sites More sharing options...
Buf-Phoon loitering with intent Lifetime Members 13,318 Member For: 20y 7m 10d Gender: Male Location: Zombie Birdhouse Posted 09/01/15 12:38 AM Share Posted 09/01/15 12:38 AM great thread mate well done.Will be following with interest.Who are getting to do the tuning work ? Link to comment Share on other sites More sharing options...
HI PSI Member 1,563 Member For: 17y 10m 4d Gender: Male Location: Central Queensland Posted 09/01/15 11:42 AM Author Share Posted 09/01/15 11:42 AM Thank you for your kind words. they are greatly appreciated.After the run in is completed, it will be going to Dave Sheehy in Mackay. Link to comment Share on other sites More sharing options...
Buf-Phoon loitering with intent Lifetime Members 13,318 Member For: 20y 7m 10d Gender: Male Location: Zombie Birdhouse Posted 09/01/15 11:49 AM Share Posted 09/01/15 11:49 AM Yep CPV , carry on. Bit of a legend around here for us veterans, It will go fast.Daves produced the odd nugget of his own LOL Link to comment Share on other sites More sharing options...
HI PSI Member 1,563 Member For: 17y 10m 4d Gender: Male Location: Central Queensland Posted 09/01/15 12:18 PM Author Share Posted 09/01/15 12:18 PM (edited) I finished stripping the engine bay today. I have removed the battery tray, as it reduce the room for the hot side piping and turbo intake. In regards to the informatio below, I battled to describe it a way that all members could understand. My apologies....I also dummy fitted the Plazmaman 1900hp intercooler. this required the a little massaging of the Rio. With this, I fitted the hot and cold side piping from the cooler to the headlight and this is where I hit a hurdle. As many before me have found, the limited space between the body and the headlights limits piping size to 3 inches in diameter. Even then, intercooler piping will not fit through there and a silicon joiner has to be run through the area. The joinert is squashed/distorted between the body and the light.and as you could well understand, this is an obvious are of restriction and an area that could be improved.So came the question, how can I increase flow without making obvious illegal modifications eg: Cutting holes in the body where the battery and air box used to be and running the piping through them? With this, I decided to modify the shape of the area under the headlight, to allow 69mm piping to pass through the area unrestricted. I managed this, by scalloping out the material where the piping ran under the light, and welded in a section with a larger diameter.Unfortunately, I didn't get a chance to take any pictures today. I will post some tomorrow night, and I am sure that it will clarify what I attempted to explain..CheersBrad Edited 09/01/15 12:20 PM by HI PSI 1 Link to comment Share on other sites More sharing options...
"Captain Retard" Member 1,417 Member For: 9y 10m 27d Gender: Male Location: Shellharbour NSW Posted 10/01/15 03:52 AM Share Posted 10/01/15 03:52 AM Great thread mate!You certainly have been saving your pennies for this build lol.Good luck with it all, will be following with great interest. 1 Link to comment Share on other sites More sharing options...
genuine honest person Member 2,769 Member For: 10y 2m 1d Gender: Male Location: near brisbane Posted 10/01/15 05:58 AM Share Posted 10/01/15 05:58 AM how easy is it to fit the engine and box with the hoist ,I done it all with just a engine crane and stands . great work mate Link to comment Share on other sites More sharing options...
HI PSI Member 1,563 Member For: 17y 10m 4d Gender: Male Location: Central Queensland Posted 10/01/15 07:24 AM Author Share Posted 10/01/15 07:24 AM I was amazed at how much fasted and easier it was. I will never do it any other way again...... \ said: Great thread mate! You certainly have been saving your pennies for this build lol. Good luck with it all, will be following with great interest. Hi Captain, I'm glad that you like the thread. I just want to share my experience with others, and maybe help out if I can.. I shudder to think of how much I have spent already..... Every section of the car costs thousands of dollars. Continuing from yesterdays post. I finished notching the drivers side today, with the passengers side now 75% complete. The pipe fit through under the headlight with sufficient clearance...... 1 Link to comment Share on other sites More sharing options...
