raz1911 Member 110 Member For: 10y 11m 9d Gender: Male Posted 24/12/14 10:48 AM Share Posted 24/12/14 10:48 AM Talk about going all out! Nice build mate. Hope everything goes well. 1 Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 27d Gender: Male Location: Perth Posted 24/12/14 11:55 AM Share Posted 24/12/14 11:55 AM Might be a good option to change the coils for genuine ford. Considering all the cash you have spent don't scrimp on the coils Link to comment Share on other sites More sharing options...
HI PSI Member 1,572 Member For: 17y 10m 29d Gender: Male Location: Central Queensland Posted 24/12/14 12:05 PM Author Share Posted 24/12/14 12:05 PM Excellent build mate, no cut corners, no B/SWell done !Just something to keep in mind is the bosch 2200cc injectors HAD issues with E85 not being compatible, unsure if this has changed recently but keep it in mind Thank you. I greatly appreciate your feedback and I will investigate this further when the supplier reopens after Christmas. Link to comment Share on other sites More sharing options...
HI PSI Member 1,572 Member For: 17y 10m 29d Gender: Male Location: Central Queensland Posted 24/12/14 12:07 PM Author Share Posted 24/12/14 12:07 PM Might be a good option to change the coils for genuine ford. Considering all the cash you have spent don't scrimp on the coilsHere I was thinking that they were the same... Silly me.... Thank you for the advice, I really appreciate it. Link to comment Share on other sites More sharing options...
HI PSI Member 1,572 Member For: 17y 10m 29d Gender: Male Location: Central Queensland Posted 24/12/14 12:12 PM Author Share Posted 24/12/14 12:12 PM I am chasing a high flow 10 micron high flow fuel filter, that has a metal, re washable element. The larger the surface area of the filter and size, the better..... I would greatly appreciate any input that forum members could give me on brand and models of filters......... Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 27d Gender: Male Location: Perth Posted 24/12/14 12:32 PM Share Posted 24/12/14 12:32 PM Ralph wiggum will be able to answer this Link to comment Share on other sites More sharing options...
GeGe6 Donating Members 1,978 Member For: 11y 9m 16d Gender: Male Location: Perth, SOR Posted 24/12/14 03:22 PM Share Posted 24/12/14 03:22 PM Bit of info here. http://www.fordxr6turbo.com/forum/index.php?/topic/80699-Aftermarket-Fuel-Filters%2E%2E%2Ewhat-I-Did%21 Link to comment Share on other sites More sharing options...
HI PSI Member 1,572 Member For: 17y 10m 29d Gender: Male Location: Central Queensland Posted 06/01/15 03:02 AM Author Share Posted 06/01/15 03:02 AM Thanks for the information. It is greatly appreciated.. After assembling the short in late October, I decided to install larger valves and do major porting of the cylinder head. Given the size of the valves, we dummy fitted the head so that we could determine what clearance we had on on the valve relief's, on the pistons. After we determined the centre of the valve, we realised that the clearances were a little too close for comfort. So, the bottom was disassembled and the pistons milled. Before machining: After machining: As you can see, the remaining material at the outer edge of the piston was unacceptably thin, so it was removed. The whole bottom end was then recleaned and components and the reassembly initiated. Upon installing the oil pick up (wasn't installed previously), we identified a problem. In it's standard configuration, the bottom oil pick up would only clear the bottom of the sump by 2mm. We also noted, that due to the addition of the mains stud girdle, the height if the pick up mount was increased. This caused the pick up flange (at the oil pump) to be misaligned with the oil pump. In order to rectify the problem, we made minor adjustments to the lenght two main studs. The first to be adjusted, was a stud that was positioned directly under the middle of the pick up tube, as it was touching the pick up. The other was the studs that the pick up's brace attaches to. Despite lowering the mounting height of the pick up, we found that it was not sufficient to square up the flange. So, we cut about 10mm of material from the pick up brace ans rewelded the mount. Problem solved..... Unfortunately, as I have not completed polishing the timing cover, assembly ceased. Stay posted, more updates soon.... I was only thinking about my problems with the splitters for the DJR kit the other day. So, while browsing Ebay, I performed a search for "DJR". Much to my delight, I found these... NOS - Genunie DJR splitters. So, I snapped them up and they are in transit. If anyone else is interested in a set, they have another set listed.... The Drive Shaft Shop 1400hp drive shafts arrived today. The picture really doesn't show how big these things really are. With any luck, I will have the new IRS and fuel system fitted before the car gets its engine bay painted on Sunday. Link to comment Share on other sites More sharing options...
hoarspower Member 478 Member For: 12y 7m 11d Gender: Male Location: brisbane Posted 06/01/15 03:37 AM Share Posted 06/01/15 03:37 AM A mate has one of those ss throttle bodies and has had nothing but trouble with it especially idling, hope you done have any dramas with yours, awesome bulid too mate ! Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 10m 23d Gender: Male Location: Adelaide Posted 06/01/15 06:55 AM Share Posted 06/01/15 06:55 AM Hey nice one, quick question... When u fly cut the pistons what was your P-V clearance, were u already in the single digits? What was the after P-V ? Your right its very thin going around the skirts Link to comment Share on other sites More sharing options...
