nathanway Member 106 Member For: 12y 8m 19d Gender: Male Location: townsville Posted 22/10/14 10:35 PM Share Posted 22/10/14 10:35 PM hey guysive just upgraded my turbo to a gtx3582 on my auto fg xr6tbut the guys at mtq stuffed up the gate mod and boost cant be controlled below 18psiand 18psi is way to much for the stock fuel systemso im going to go a plasmaman surge with twin 044s or walbro 460's ready for e85 when it come to townsvillebut the cam chain guides are worn out so while ive got it apart I wanna do the oil pump and a nice set of camsive gotta few questionsis it worth it going for twin pumps ive hurd ill have to change the fuel regif I go the twin pumps should I go the fuel rail as well I plan on running e85and whats the biggest cams I can run with the auto and stock converterdo I need to change the intire oil pump housing and or just the gearsshort term plans are to run 19-21 psi on 98 fuel and around the 400-420kw mark with a mid to high 10sec 1/4mile Link to comment Share on other sites More sharing options...
TomT Spooling Member Donating Members 961 Member For: 12y 4m 18d Gender: Male Location: Blue Mountains, NSW Posted 28/10/14 02:44 AM Share Posted 28/10/14 02:44 AM (edited) For E85 to be safe you'll want the twin pump setup (assuming you've chosen external surge option), fuel reg, fuel rail and all teflon/ethanol compatible fuel lines. Also best to upgrade the intank aswell if you haven't already.As for the oil pump, you can either purchase a complete race oil pump or buy the oil pump gears and modify the stock pump housing.BTW I think you're posting in the wrong section. Edited 28/10/14 02:45 AM by TomT Link to comment Share on other sites More sharing options...
