luke187 Member 297 Member For: 10y 4m 13d Posted 19/10/14 10:25 PM Share Posted 19/10/14 10:25 PM A few american forums I've read recommended to use redline d4, costs $90 for 4l which sounds a lot better than a couple hundred. Rollover noise is ridiculous my car with the light clutch and solid plates - have started to get used to it but if I can get rid of it I will. Link to comment Share on other sites More sharing options...
f-wolf Member 897 Member For: 16y 11m 25d Gender: Male Location: ACT Posted 19/10/14 11:08 PM Share Posted 19/10/14 11:08 PM http://www.penriteoil.com.au/products.php?id_categ=4&id_products=374 DescriptionPro Gear 70W-75 is a premium full synthetic, high performance oil manufactured from a blend of synthetic base oils including ester. It uses the latest technology, purpose designed additives for long service life and meets the performance requirements of API GL-4 Plus as well as many other manufacturer specifications.Pro Gear 70W-75 is primarily designed for 5 & 6 speed manual gearboxes and transaxles in passenger cars, 4WDs & light commercial vehicles such as -BMW, Ford Falcon XR/FPV BA/BF/FG (T-56)Expensive Daewoo VY/VZ/VE 6 Speed (T-56), Jaguar S 2.7L DLand Rover Discovery 3/Freelander 2VW 6 speed gearboxes (non-DSG)ZF gearboxes S5-31, S5-39, S6-37 and S6-53Pro Gear 70W-75 is ideal in manual gearboxes and transfer cases that require automatic transmission fluids, or in vehicles that are suffering from shift quality problems with higher viscosity fluids. Link to comment Share on other sites More sharing options...
BRK Member 361 Member For: 12y 4m 6d Gender: Male Location: Perth Posted 19/10/14 11:34 PM Share Posted 19/10/14 11:34 PM The rollover rattle in the t56 ... Have played around with idle speeds in the tune but no luck. Went up/down in the 600 to 900 as a range and got a fair compromise a while back but it is not great. With the aircon on and a MW3+ clutch, the rattle is there. and.... it was there witht stock clutch as well. Link to comment Share on other sites More sharing options...
f-wolf Member 897 Member For: 16y 11m 25d Gender: Male Location: ACT Posted 21/10/14 02:33 AM Share Posted 21/10/14 02:33 AM (edited) Just went to one place to get some Penrite Pro Gear 70W-75... $ 70.00 for 2.5 litres Went to Repco... $ 46.00 for 2.5 Litres.... Minus 20% http://www.repco.com.au/CA2571B70016E7AE/OrigDoc/~B865C63C95E002BDCA25770E0021AE33?OpenDocument5 Litres, $ 73.60Sales Person ordered 2x 2.5 Litres for me....Will pick it up tomorrow after 8 AM. Edited 21/10/14 02:38 AM by f-wolf 1 Link to comment Share on other sites More sharing options...
luke187 Member 297 Member For: 10y 4m 13d Posted 22/10/14 12:37 AM Share Posted 22/10/14 12:37 AM keen to hear your results. Link to comment Share on other sites More sharing options...
Trent0 The Toxic Rocket Donating Members 574 Member For: 13y 11m 26d Gender: Male Location: Brisbane Posted 22/10/14 08:03 AM Share Posted 22/10/14 08:03 AM I've picked up my solution to the t56 rollover noise yesterday. . . Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,292 Member For: 16y 9d Gender: Male Location: Melbourne Posted 22/10/14 08:49 AM Share Posted 22/10/14 08:49 AM That's a fail ^^^ 3 Link to comment Share on other sites More sharing options...
f-wolf Member 897 Member For: 16y 11m 25d Gender: Male Location: ACT Posted 25/10/14 02:14 AM Share Posted 25/10/14 02:14 AM keen to hear your results.Just done it... Managed to get 5 Litres in to the Gearbox by jacking the left side up so the Car is at an angle ( 2 Stands used) !!Took it for a run... Happy with Gear-Change and Roll-Over noise.The Oil ( Penrite 70W-75 ) looks like Olive Oil.Only Tool needed is a 3/8" T-Bar, or Heavy Duty 3/8" Ratchet to undo Drain/ Filler Plug. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,292 Member For: 16y 9d Gender: Male Location: Melbourne Posted 25/10/14 02:18 AM Share Posted 25/10/14 02:18 AM Good result!Did you fill it via the reverse switch? Link to comment Share on other sites More sharing options...
f-wolf Member 897 Member For: 16y 11m 25d Gender: Male Location: ACT Posted 25/10/14 02:46 AM Share Posted 25/10/14 02:46 AM (edited) Good result!Did you fill it via the reverse switch?NO ! ...jacking the left side up so the Car is at an angle ! Both left Wheels ( N/S) off the ground ( 2 Stands used) By having the Car at an angle you can use the filler plug on the left side (N/S) to fill the Gearbox.No need to remove the Reverse Switch !! Edited 25/10/14 02:49 AM by f-wolf 1 Link to comment Share on other sites More sharing options...
