Bizkets is Drunk? Too heavy needs boost Member 5,929 Member For: 10y 7m 22d Gender: Male Location: Adelaide Posted 03/10/14 10:45 PM Share Posted 03/10/14 10:45 PM haven't set a actuator pre load before. can someone give me a idea how to set pre load. my turbo is off the car. Link to comment Share on other sites More sharing options...
I JET Member 325 Member For: 11y 2m 20d Gender: Male Location: Wollongong Posted 04/10/14 12:22 AM Share Posted 04/10/14 12:22 AM The turbo smart installation manual said to adjust the actuator rod until the hole on the end overlaps the pin on the flapper arm by 2mm with the flap closed. Than use pressure ( compressed air ) to operate the actuator so the hole & pin can be aligned and installed. Hope this makes sense. The manual had pictures & diagrams with helped explain it. 1 Link to comment Share on other sites More sharing options...
camo86T Silver Donating Members 1,810 Member For: 10y 1m 16d Gender: Male Location: SW Sydney Posted 04/10/14 11:22 AM Share Posted 04/10/14 11:22 AM Was going to ask the same question sometime soonSo is that amount of preload pretty std across the board regardless of turbo, actuator etc.?I need to set preload on the billet wheeled GT3582 I got together for my FGThough the guy before me put a cut in the actuator outer rod and then by the look of it squeezed it in the vice to keep from moving... so if possible I will be just adjusting the rotation of the front cover to suit, at least as far as cooler pipework allows.And then I'm guessing the idea is to hit the actuator with compressed air with a gauge in the line to check psi that actuator flapper cracks open?Appreciate any pointers and/or constructive criticism, cheers 1 Link to comment Share on other sites More sharing options...
I JET Member 325 Member For: 11y 2m 20d Gender: Male Location: Wollongong Posted 04/10/14 11:36 AM Share Posted 04/10/14 11:36 AM ^ this was my first time setting one up so I just followed the instructions that came with the actuator. Maybe someone with greater knowledge can chime in. To me that seems logical as you need some sort of spring pressure holding the flap shut, but obviously you dont want too much as your are reducing the actuator travel by doing so. I can't think of any reason why having more than, or less than -2mm would be beneficial. 1 Link to comment Share on other sites More sharing options...
camo86T Silver Donating Members 1,810 Member For: 10y 1m 16d Gender: Male Location: SW Sydney Posted 04/10/14 11:58 AM Share Posted 04/10/14 11:58 AM Sounds right to meI've seem the phrase "half a hole preload" thrown around a bit too...sort of tech spec I like lol Link to comment Share on other sites More sharing options...
Bomber Carnage on the Garage Floor Donating Members 3,994 Member For: 13y 10m 17d Gender: Male Location: Gold Coast Posted 05/10/14 01:22 AM Share Posted 05/10/14 01:22 AM 2-3mm is the norm but Turbosmart run less from memory. If off the car I'd set at that then check operation at full stroke with compressed air. Make sure it tracks correctly, as in geometry is correct, if you've changed the bracket or combo. Sometimes the arm needs an offset to get it spot on. 3 Link to comment Share on other sites More sharing options...
