Banjora07 Member 66 Member For: 12y 4m 15d Posted 20/09/14 07:27 AM Share Posted 20/09/14 07:27 AM Hey guys just got my turbo rebuilt but still pumping out smoke on declaration been told it might be value steam seals but had a leak down test and got two cylinders are low its a bf typhoon all the usual mods just wondering if anyone had same problem thanks Link to comment Share on other sites More sharing options...
"Captain Retard" Member 1,417 Member For: 9y 10m 26d Gender: Male Location: Shellharbour NSW Posted 20/09/14 08:33 AM Share Posted 20/09/14 08:33 AM (edited) You can't tell if it's valve stem seals by a leak down test as the valves would be closed.But bad valve stem seals will blow smoke.How much are the cylinder pressures down?What are the pressures?Within 10% ain't to bad! Edited 20/09/14 08:34 AM by "Captain Retard" Link to comment Share on other sites More sharing options...
Banjora07 Member 66 Member For: 12y 4m 15d Posted 20/09/14 08:51 AM Author Share Posted 20/09/14 08:51 AM Yeah its just a guess with the values idk mechinc did it there telling me rebuild but if I can just do my head up and do bottom end next year would be good Link to comment Share on other sites More sharing options...
Banjora07 Member 66 Member For: 12y 4m 15d Posted 21/09/14 10:40 AM Author Share Posted 21/09/14 10:40 AM No one come across this before blowing smoke only when slowing down always thought my car was a one off one off sh*tbox Link to comment Share on other sites More sharing options...
sexual harrassment panda I see a red door and I want to paint it black Donating Members 5,919 Member For: 14y 5m 3d Gender: Male Location: Far north queensland Posted 21/09/14 07:57 PM Share Posted 21/09/14 07:57 PM Yeah its just a guess with the values idk mechinc did it there telling me rebuild but if I can just do my head up and do bottom end next year would be goodso he can't give you the results of the test but is telling you that you need a rebuild? Link to comment Share on other sites More sharing options...
frozenxr6t Member 140 Member For: 9y 7m 14d Posted 19/10/15 06:26 PM Share Posted 19/10/15 06:26 PM want ended up happening here. ive got smoke on startup and when sitting at lights etc. but nothing whilst cruising or under power Link to comment Share on other sites More sharing options...
Peppy_t92 Silver Donating Members 748 Member For: 10y 11m 26d Gender: Male Location: Liverpool Posted 21/10/15 04:28 AM Share Posted 21/10/15 04:28 AM This is becoming more and more common in BA's as they get older... Typically if it's the valve stem seals it will blow smoke during high vacuum periods, so idle, taking off... If the turbo is good and comp/leak down test comes up alright, there's a good chance it's the seals... It can be done on the car, but requires the valve springs to come off, so if you have already done them, they have to come off again, if not then lucky you.. If it's at the stage where your seals are stuffed then there's also a good chance that the head is due for a service 2 Link to comment Share on other sites More sharing options...
frozenxr6t Member 140 Member For: 9y 7m 14d Posted 25/10/15 08:13 AM Share Posted 25/10/15 08:13 AM yea the ba ive got has this problem im sure of it. never blows smoke unless at idle and take of from a period of waiting(stoplights etc) so im going to do valve springs and stem seals soon I reckon. Link to comment Share on other sites More sharing options...
