UWNTM3 Member 78 Member For: 12y 5m 29d Gender: Male Location: Bathurst NSW Posted 26/08/14 06:33 AM Share Posted 26/08/14 06:33 AM Hey guys The switch has been dicky in my passenger front window for weeks now and hasnt been working, now all of a suddon the driver and the passenger will not work? From the master unit on drivers door I can open both back windows and the back switches work aswell but front wont move at all, I had a look at the fuses but theres no fuse layout on the cover where do I find that? Anyone know if they run on 2 seperate fuses fronts and then backs or if they even have a fuse?Any help would be great cheers Link to comment Share on other sites More sharing options...
rokkie Member 87 Member For: 11y 7m Gender: Male Location: Adelaide, SA Posted 26/08/14 10:44 AM Share Posted 26/08/14 10:44 AM There should be 3 big pink 30 amp fuses. One is for front power windows. The passenger side switch is normally the cause for the short circuit. Link to comment Share on other sites More sharing options...
ranuip Member 25 Member For: 10y 8m 14d Posted 06/09/14 12:34 AM Share Posted 06/09/14 12:34 AM Mine just did the same thing today, but only the passenger side. Pulled out and put fuse back in, now all good. Link to comment Share on other sites More sharing options...
Box stock T. Member 1,384 Member For: 9y 13d Posted 09/10/20 11:10 PM Share Posted 09/10/20 11:10 PM This maybe an old thread, but I just tried this trick on my son's FG window rocker switch and it works a treat. So worth trying before any of you FG owners go trying to remove the door panels or switch or even taking it to an auto spark. Time to fix : 2 mins Cost : $0. Result : F@RKING GOLD. #Fordxr6turbo.comfor/the/win. Link to comment Share on other sites More sharing options...
