ratter Member 6,793 Member For: 17y 10m 28d Gender: Male Location: @ my laptop Posted 09/08/14 12:16 PM Share Posted 09/08/14 12:16 PM with supporting mods and on 98 approx 400 give or take a few rwkw either way 3 Link to comment Share on other sites More sharing options...
Slowxr6t Member 516 Member For: 5y 4m 20d Location: New zealand Posted 10/01/19 06:06 AM Share Posted 10/01/19 06:06 AM I can get a Garrett 3582 core and .70 comp housing to slot into the stock turbine housing for $1700nzd but there's no mounting hole or bracket on the .70 comp housing for the wastegate actuator. Does anyone know if it's possible to weld something on the housing to hold the actuator? I'm thinking if I could make it work it would be a relatively easy turbo upgrade. It would have a 6mm bigger compressor wheel and housing to suit. Anyone know how much more lag it will have? Opinions would be really appreciated Sorry I have a 15 fgx turbo, I didn't mention that Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,302 Member For: 16y 14d Gender: Male Location: Melbourne Posted 10/01/19 06:13 AM Share Posted 10/01/19 06:13 AM The same bolts that hold the "front-housing" to the compressor-side backplate are the ones you can use to put the bracket around the outside that the actual actuator mounts to. You use the same bracket and actuator from your stock turbocharger. The lag is only a couple of hundred rpm worse than the stock turbo, but requires you to be more "obvious" with your intentions to hit boost to get over the threshold. Link to comment Share on other sites More sharing options...
Slowxr6t Member 516 Member For: 5y 4m 20d Location: New zealand Posted 10/01/19 06:56 AM Share Posted 10/01/19 06:56 AM Thanks Keith, have you done this turbo mod? Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,302 Member For: 16y 14d Gender: Male Location: Melbourne Posted 10/01/19 07:23 AM Share Posted 10/01/19 07:23 AM nah, just replaced the CHRA on enough GT3582R's and swapped a CHRA of a "baby FG turbo" into a GT3582R housing setup. It's not an overly complex thing to do, you just need the right tools (something to mount the housings so you can get the bolts out and appropriate spanners, essentially) Link to comment Share on other sites More sharing options...
ilk Is on holiday from communism Member 1,282 Member For: 5y 3m 22d Gender: Female Location: Victoria Posted 10/01/19 09:36 AM Share Posted 10/01/19 09:36 AM What's a chra? Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,127 Member For: 9y 2m 26d Gender: Male Location: South Australia Posted 10/01/19 09:39 AM Share Posted 10/01/19 09:39 AM Clicky! 2 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,302 Member For: 16y 14d Gender: Male Location: Melbourne Posted 10/01/19 09:40 AM Share Posted 10/01/19 09:40 AM http://lmgtfy.com/?q=CHRA haha great minds think alike, eh, Nath 2 Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,127 Member For: 9y 2m 26d Gender: Male Location: South Australia Posted 10/01/19 09:41 AM Share Posted 10/01/19 09:41 AM @k31th Link to comment Share on other sites More sharing options...
ilk Is on holiday from communism Member 1,282 Member For: 5y 3m 22d Gender: Female Location: Victoria Posted 10/01/19 09:59 AM Share Posted 10/01/19 09:59 AM Thanks Link to comment Share on other sites More sharing options...
