Rab WOT? Moderating Team 10,981 Member For: 12y 4m 24d Gender: Male Location: Frankston, 3199 Posted 02/08/14 12:39 PM Share Posted 02/08/14 12:39 PM (edited) Hey guys,Stumbled across a whole subculture on the forum talking about water injection.I've got absolutely no idea what they are doing, but it seems pretty interesting.Is anyone able to give me the cliff notes and let me know if it's something that should be investigated further? Edited 02/08/14 12:47 PM by Rab 2 Link to comment https://www.fordxr6turbo.com/forum/topic/88870-water-injection-for-dummies/ Share on other sites More sharing options...
MattyP MattyP Cruise Control 6,317 Member For: 13y 2m 15d Gender: Male Location: Central Coast Posted 02/08/14 01:08 PM Share Posted 02/08/14 01:08 PM Long story short Yes It's brilliant My Christmas present is a water injection kitEssentially Highly vaporized water goes in (nozzle can be pre or post turbo) lowers IAT, raises octane. So more boost, more spark and a cleaner engine.It's just brilliant Link to comment https://www.fordxr6turbo.com/forum/topic/88870-water-injection-for-dummies/#findComment-1489471 Share on other sites More sharing options...
Rab WOT? Moderating Team 10,981 Member For: 12y 4m 24d Gender: Male Location: Frankston, 3199 Posted 02/08/14 01:20 PM Author Share Posted 02/08/14 01:20 PM So needs to be tuned for it?Is it something that can be on or off or is it a full time commitment?Windscreen wiper size bottle you need to keep full all the time or a 50l tank?Does it work with LPG?Remember - this is for dummies Link to comment https://www.fordxr6turbo.com/forum/topic/88870-water-injection-for-dummies/#findComment-1489475 Share on other sites More sharing options...
MattyP MattyP Cruise Control 6,317 Member For: 13y 2m 15d Gender: Male Location: Central Coast Posted 02/08/14 01:24 PM Share Posted 02/08/14 01:24 PM hahaFor the full advantagesYes it will need to be tuned. you can add spark but ill be just removing some fuelI want it for having a 91 E10 tune. With water injection it'll behave similar/better than 98.Yes it will work on lpgRemember Rab Questions are good, Questions means thought and questions means learning 1 Link to comment https://www.fordxr6turbo.com/forum/topic/88870-water-injection-for-dummies/#findComment-1489479 Share on other sites More sharing options...
MattyP MattyP Cruise Control 6,317 Member For: 13y 2m 15d Gender: Male Location: Central Coast Posted 02/08/14 01:44 PM Share Posted 02/08/14 01:44 PM In a piston engine, the initial injection of water cools the fuel-air mixture significantly which increases its density and hence the amount of mixture that enters the cylinder. The water (if in small liquid droplets) may absorb heat (and lower the pressure) as the charge is compressed, thus reducing compression work.[1] An additional effect comes later during combustion when the water absorbs large amounts of heat as it vaporizes, reducing peak temperature and resultant NOx formation, and reducing the amount of heat energy absorbed into the cylinder walls. This also converts part of combustion energy from the form of heat to the form of pressure. As the water droplets vaporize by absorbing heat, they turn to high pressure steam. The net result is a higher octane charge that will support very high compression ratios or significant forced induction pressures before onset of detonation.Wikipedia does a pretty good job of explaining it 5 Link to comment https://www.fordxr6turbo.com/forum/topic/88870-water-injection-for-dummies/#findComment-1489483 Share on other sites More sharing options...
genuine honest person Member 2,769 Member For: 11y 5m 21d Gender: Male Location: near brisbane Posted 02/08/14 01:55 PM Share Posted 02/08/14 01:55 PM great info , Matty Link to comment https://www.fordxr6turbo.com/forum/topic/88870-water-injection-for-dummies/#findComment-1489484 Share on other sites More sharing options...
"Captain Retard" Member 1,417 Member For: 11y 2m 17d Gender: Male Location: Shellharbour NSW Posted 02/08/14 09:23 PM Share Posted 02/08/14 09:23 PM If and when I get the wife's FG tuned then the water meth route will be something I'll be looking into.I'll be doing it for similar reasons to MattyP , running E10 94 and a safe tune! 1 Link to comment https://www.fordxr6turbo.com/forum/topic/88870-water-injection-for-dummies/#findComment-1489509 Share on other sites More sharing options...
GeGe6 Donating Members 1,980 Member For: 13y 12d Gender: Male Location: Perth, SOR Posted 02/08/14 10:55 PM Share Posted 02/08/14 10:55 PM Ok that's all the good stuff, what disadvantages or possible issues can it present. Link to comment https://www.fordxr6turbo.com/forum/topic/88870-water-injection-for-dummies/#findComment-1489519 Share on other sites More sharing options...
"Captain Retard" Member 1,417 Member For: 11y 2m 17d Gender: Male Location: Shellharbour NSW Posted 02/08/14 11:25 PM Share Posted 02/08/14 11:25 PM Besides one more thing to go wrong and another tank to fill , I don't think there are any real disadvantages provided it's set up correctly!These systems have been around for about as long as the internal combustion engine has, so they should be relatively reliable.Their operation is pretty simple.I seriously looked at a water meth system about 20 years ago when I was running a high compression cleveland but after a camshaft change (more duration) solved some of my issues.A lot of people frown upon them as a "bandaid "solution but they do have merit IMHO ! 1 Link to comment https://www.fordxr6turbo.com/forum/topic/88870-water-injection-for-dummies/#findComment-1489523 Share on other sites More sharing options...
barnz Member 3,047 Member For: 11y 7m 29d Gender: Male Location: Brisbane Posted 03/08/14 02:22 AM Share Posted 03/08/14 02:22 AM Would be interesting to see what gains can be made on a stock car with a tune given it's relatively cheap to set up compared to new cooler ect. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/88870-water-injection-for-dummies/#findComment-1489548 Share on other sites More sharing options...
