JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 10m 19d Gender: Male Location: Adelaide Posted 16/05/15 02:54 AM Share Posted 16/05/15 02:54 AM Brads on it but the other way around ....... Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 10m 19d Gender: Male Location: Adelaide Posted 16/05/15 02:55 AM Share Posted 16/05/15 02:55 AM Gaz really that's your answer ?If u want to know be constructive ffs Link to comment Share on other sites More sharing options...
eff xr6t Member 569 Member For: 10y 6m 21d Posted 16/05/15 02:58 AM Share Posted 16/05/15 02:58 AM (edited) What kind of timing are you seeing on e85 and say 26psi jet and gav?I gave my mates El sohc 4l a tune the other night on the Dyno torque peaked around 12* at 26psi and 6500rpm made 445rwkw. Curios how much you see in a dohc motor to compare. Edited 16/05/15 03:05 AM by eff xr6t Link to comment Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,751 Member For: 12y 8m 30d Posted 16/05/15 03:06 AM Author Share Posted 16/05/15 03:06 AM No idea on timing. I'm not a tuner. If you add fuel its going to keep it cool, so lean it out to make power and raise temps Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 10m 19d Gender: Male Location: Adelaide Posted 16/05/15 03:14 AM Share Posted 16/05/15 03:14 AM Well well well There we go Lean out 98 temps rise and see pre ignition lean out something that's already around ( lets just use 30% cooler because its an easy reference figure for e85 ) and u get ..... A desired lambda for E85 under big power How much leaner u think ?30% of a total ? Sounds ballpark yeh Look here as a few quick finds Link to comment Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,751 Member For: 12y 8m 30d Posted 16/05/15 03:36 AM Author Share Posted 16/05/15 03:36 AM Sorry am I missing something. Micks tune is showing .85 lambda throught the curve. My tune at its worst part is .88 lambda .Is that enough to cause a issue like this. Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 10m 19d Gender: Male Location: Adelaide Posted 16/05/15 03:41 AM Share Posted 16/05/15 03:41 AM Each tuner has there own way 0.9 lambda is used by some others will go .85See how small amounts can influence different outcomes, pressure is moved by large amounts on small tweaks Your sheet should be up around 12.8-13.2 Link to comment Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,751 Member For: 12y 8m 30d Posted 16/05/15 03:45 AM Author Share Posted 16/05/15 03:45 AM I'm confused. You want me to lean it out? Sounds against what my problem is. Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 10m 19d Gender: Male Location: Adelaide Posted 16/05/15 03:53 AM Share Posted 16/05/15 03:53 AM Right well I think you should do what ever you want then Link to comment Share on other sites More sharing options...
ms700 Moderating Team 10,170 Member For: 21y 2m 19d Gender: Male Location: Sydney Posted 16/05/15 03:56 AM Share Posted 16/05/15 03:56 AM But cocaine and strippers can get expensive 8 Link to comment Share on other sites More sharing options...
