NA_TURBO Member 532 Member For: 8y 6m 15d Gender: Male Location: Mildura Posted 07/09/19 08:19 PM Share Posted 07/09/19 08:19 PM Turbo seal, it's leaking oil into the exhaust housing. Does it mainly do it at idle? Link to comment Share on other sites More sharing options...
bjc Donating Members 2,812 Member For: 20y 7m 19d Gender: Male Location: Townsville Posted 07/09/19 11:53 PM Share Posted 07/09/19 11:53 PM How'd you go@gaz097? Was it the turbo leaking? Not an oil pressure issue? (I assume you can log/monitor this) Link to comment Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,751 Member For: 12y 9m 2d Posted 08/09/19 03:15 AM Author Share Posted 08/09/19 03:15 AM No I can't monitor oil pressure The turbo is less then 2000 Kay's old, rebuilt by procharge so I would hope not. Its done it twice now, about every 10th drive. The last time it done it was I was driving casually home from work, and I noticed it when I pulled into the driveway. About a minute later it was all good no smoke at all. Link to comment Share on other sites More sharing options...
NA_TURBO Member 532 Member For: 8y 6m 15d Gender: Male Location: Mildura Posted 08/09/19 04:19 AM Share Posted 08/09/19 04:19 AM Not sure what turbo you have, but with some you need an oil restrictor so it doesn't blow the seals. Link to comment Share on other sites More sharing options...
Tom Tucker Donating Members 615 Member For: 4y 9m 23d Posted 08/09/19 05:04 AM Share Posted 08/09/19 05:04 AM How do you rate procharge? How legit are their claims that the 64mm will do 550rwkw and reach full boost at 3000rpm? Everything I've seen suggests it's laggier than a gen2 gtx3582. Figured you're the man to ask Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 27d Gender: Male Location: Perth Posted 08/09/19 05:50 AM Share Posted 08/09/19 05:50 AM On 26/08/2019 at 6:47 PM, OZYWALKER said: No Just no I mean if you want 1st to go 100+ and to cruise on 6th at 200. If your real keen get the GT ratio box. Longer first with the rest being closer ratio. I get no grip until 4th,even 4th can spin. Just too much power through 3.73. Needs higher to grip. 2.73 would be perfect. Great for racewars to. Link to comment Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,751 Member For: 12y 9m 2d Posted 08/09/19 07:21 AM Author Share Posted 08/09/19 07:21 AM How do you rate procharge? How legit are their claims that the 64mm will do 550rwkw and reach full boost at 3000rpm? Everything I've seen suggests it's laggier than a gen2 gtx3582. Figured you're the man to ask It's laggier then a gen 1 GTX 3582. That's all I can compare to. Link to comment Share on other sites More sharing options...
camo86T Silver Donating Members 1,810 Member For: 10y 2m 11d Gender: Male Location: SW Sydney Posted 08/09/19 10:12 AM Share Posted 08/09/19 10:12 AM 4 hours ago, arronm said: I get no grip until 4th,even 4th can spin. Just too much power through 3.73. Needs higher to grip. 2.73 would be perfect. Great for racewars to. Would go 2 fitty for sure..... 3 1 Link to comment Share on other sites More sharing options...
NA_TURBO Member 532 Member For: 8y 6m 15d Gender: Male Location: Mildura Posted 10/09/19 10:55 AM Share Posted 10/09/19 10:55 AM Got it sorted out Gaz? Link to comment Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,751 Member For: 12y 9m 2d Posted 10/09/19 11:21 AM Author Share Posted 10/09/19 11:21 AM Err I have driven it every day since with no issues. Didn't do anything though The turbo came back from procharge with a feed nipple in it. Looked about the right size. Link to comment Share on other sites More sharing options...
