arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 2d Gender: Male Location: Perth Posted 28/08/19 12:19 AM Share Posted 28/08/19 12:19 AM No, I buy Gulf Western in 20L drum. 1 Link to comment Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,751 Member For: 12y 8m 8d Posted 03/09/19 08:17 AM Author Share Posted 03/09/19 08:17 AM Been razing around with the tr6060 in and it's so much nicer to drive with it. Shifts about a million times better. Far less roll over noise. Completely different car to drive. And the super low first gear gets it through intersections so quick. I quite like it. Problem 1 though. Cruise control does not work in 5th gear. 3rd 4th 6th still does. I think I may have solved my issue as I write this though. As it's gotta match rpm with wheel speed to know what gear it's in (also why you can't engage cruise in first and second) it can't make the connection as the ratios are different?Tuning people. Is there a gear ratio adjustment that can be changed ?Or possibly something else ? Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,240 Member For: 15y 11m 19d Gender: Male Location: Melbourne Posted 03/09/19 08:18 AM Share Posted 03/09/19 08:18 AM who sets cruise in 5th anyway? I never do... just 4th and 6th. 4th for up to 60, anything higher than 60 and I use 6th Link to comment Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,751 Member For: 12y 8m 8d Posted 03/09/19 09:25 AM Author Share Posted 03/09/19 09:25 AM Cause I can. 6thstarts creating some pretty good harmonics below 80 kph Link to comment Share on other sites More sharing options...
bjc Donating Members 2,807 Member For: 20y 6m 25d Gender: Male Location: Townsville Posted 03/09/19 09:41 PM Share Posted 03/09/19 09:41 PM Isn't cruise control over 40km/h regardless of gear? Can't really remember anymore what gear (thought it was 2nd for wow factor!) I used to drive around the base in with the 04 blown xr8 with the 5sp at 40k's with cruise control enabled...or I may have been speeding!? Link to comment Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,751 Member For: 12y 8m 8d Posted 03/09/19 11:17 PM Author Share Posted 03/09/19 11:17 PM Yeah it engages at 40, but you can hold down and go slower down to about 35 before it cuts out Link to comment Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,751 Member For: 12y 8m 8d Posted 07/09/19 01:38 PM Author Share Posted 07/09/19 01:38 PM Have a intermittent oil smoke problem. Only there occasionally but when it does it's like the photo below. After this photo was taken it cleared up about 2 minutes of ideling later. Not there on cold starts, and valve stem seals were done at engine rebuild time so have done 30k Kay's. Compression test came back 165psi pretty damn even across all cylinders. Pcv and check valve seam good. Rattle and are free to move. Any ideas? And yes it's definitely oil. Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 2d Gender: Male Location: Perth Posted 07/09/19 01:44 PM Share Posted 07/09/19 01:44 PM Turbo shaft seals Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 2d Gender: Male Location: Perth Posted 07/09/19 02:17 PM Share Posted 07/09/19 02:17 PM Broken ring Cracked top piston land Link to comment Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,751 Member For: 12y 8m 8d Posted 07/09/19 02:19 PM Author Share Posted 07/09/19 02:19 PM Would be intermittent though. Link to comment Share on other sites More sharing options...
