gaz097 Bronze Donating Members 1,751 Member For: 12y 8m 29d Posted 15/05/15 10:48 PM Author Share Posted 15/05/15 10:48 PM Lifting heads and E85 has been around for yearsHave a think what u could change to suit It all begins with the fuelLifting a head is all to do with cylinder pressure. The only thing I can change is target an initial lower boost to keep my af flat through the curve. If that's the case , it's going straight on gumtree as there boring as f*ck to drive like that. Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 10m 19d Gender: Male Location: Adelaide Posted 15/05/15 11:55 PM Share Posted 15/05/15 11:55 PM (edited) CorrectTime for a re tune People have managed 40psi on stock head gasket with e85 Edited 15/05/15 11:57 PM by Wombat Bellend Link to comment Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,751 Member For: 12y 8m 29d Posted 16/05/15 12:37 AM Author Share Posted 16/05/15 12:37 AM Yeah all well and good to make a pretty power figure at the top of your rpm range but if you want a quick car on the street you need boost down low or you are going to get walked but a much lower kw car. Speaking to my tuner earlier today and he always uses 14mm head studs. I guess this is the edge you play when you build stuff yourself. Link to comment Share on other sites More sharing options...
Buf-Phoon loitering with intent Lifetime Members 13,318 Member For: 20y 8m Gender: Male Location: Zombie Birdhouse Posted 16/05/15 01:06 AM Share Posted 16/05/15 01:06 AM (edited) Yeah all well and good to make a pretty power figure at the top of your rpm range but if you want a quick car on the street you need boost down low or you are going to get walked but a much lower kw car.still get walked if it comes on too hard to early. Mid 300s tractable rwkw is adequate for a daily IMO. Decent compromiseEdit . Soft, B4 U lot start Edited 16/05/15 01:09 AM by Buf-Phoon Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 10m 19d Gender: Male Location: Adelaide Posted 16/05/15 01:21 AM Share Posted 16/05/15 01:21 AM Gaz With the basics you can smack boost in as hard as it can make it, I don't see the issue when tuned correctly Link to comment Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,751 Member For: 12y 8m 29d Posted 16/05/15 01:26 AM Author Share Posted 16/05/15 01:26 AM So your saying if my a/f ratios were correct I wouldn't of had this problem? Is lean mixture the cause of excessive cylinder pressure? Link to comment Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,751 Member For: 12y 8m 29d Posted 16/05/15 01:48 AM Author Share Posted 16/05/15 01:48 AM This is the only decent thread I can find with some decent tuners talking such as headsex Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 10m 19d Gender: Male Location: Adelaide Posted 16/05/15 01:52 AM Share Posted 16/05/15 01:52 AM There's another reason Look further ...... Its on any big HP graph by a reputable workshop Link to comment Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,751 Member For: 12y 8m 29d Posted 16/05/15 02:00 AM Author Share Posted 16/05/15 02:00 AM Torque? Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 10m 19d Gender: Male Location: Adelaide Posted 16/05/15 02:06 AM Share Posted 16/05/15 02:06 AM Gaz I should say some wont show it lol its up to u mate I've given stacks away Think about it ! Link to comment Share on other sites More sharing options...
